Performance?
Old Nov 22, 2006 | 03:33 PM
jas142's Avatar
Default Performance?
What performance mods are out there and available for SRT-6s? And how does the transmission hold up?
Thanks.
Old Nov 22, 2006 | 06:13 PM
srtbeem's Avatar
Default Re: Performance?
There is a Renntech pulley mod available for a slight bump in hp/tq. Check down the board for posts. The trans is also an AMG reinforced/upgraded driver-adaptive unit and pretty much bulletproof. The SRT track experience guys told me the only component that may be prone to failure is the differential but only after really, really hard abuse. They also said the front discs could use an upgrade to cross-drilled ones as the stock discs have a tendency to overheat and warp under extreme (track) abuse.
Old Nov 27, 2006 | 07:38 PM
feets's Avatar
The '98 to '02 CLK 55 rotors are really nice upgrade that will fall into place like they were meant to be there. They're a little pricey but were designed and cast by AMG. It's pretty impressive stuff for a factory car. The rotors are vented, drilled, and are pinned to the center hub to allow more air flow.
Old Nov 27, 2006 | 07:42 PM
maxxm's Avatar
Do you have any pictures? Are the rotors the same size as the OEM in the SRT6? Thanks.
Old Nov 27, 2006 | 10:01 PM
MMZ_TimeLord's Avatar
Here's a site that has both the OEM CLK 55 AMG rotors and stock replacements. Slotted, solid and Cross Drilled. No Cross Drilled AND Slotted ones that I can find.
Link
If someone has found Cross Drilled and Slotted rotors for the SRT6, PLEASE give me a link to the website (not e-bay if you can help it). Thanks in advance.
Old Nov 28, 2006 | 12:07 AM
srt6_crossfire's Avatar
Price aside, which kit would you get to bump up the HP close to 400 HP? The one from Kleeman or Renntech and why?
I know the price is ridiculous but it's actually going to cheaper for me to upgrade than buy a new faster car.
Old Nov 28, 2006 | 04:10 PM
screaminjoe's Avatar
Evosport, because they have the lowest cost kit and dyno proven rear wheel hp gains.
Old Nov 29, 2006 | 04:19 PM
05blacksrt6's Avatar
i am pretty sure they use they same 5 speed trans in the srt8 cars witch have 420 hp so yeah they should hold alot.
Old Nov 29, 2006 | 05:26 PM
Sorry? The five speed automatic transmission in the SRT6 is a Mercedes NAG1 'SpeedShift' transmission. The SRT8 does not. It has a W5A580 Five-Speed Automatic.
Old Nov 29, 2006 | 05:35 PM
VQ35DE's Avatar
Sorry but the SRT-6 DOES have the W5A580 in it. The 2005 Limited and the 2004 automatic is the W5A330.
Old Nov 29, 2006 | 06:01 PM
Hmm... I sit corrected... I did not know that, nor could I find that information anywhere.
Thanks for setting me straight. (the NAG1 is what the Service Manual states the transmission type is, probably a Chrysler number).
Old Dec 4, 2006 | 01:16 AM
Eracer76's Avatar
Do you have the facts to prove this?
I'm finding it hard to believe that they would use a transmission from an American Hemi car in the German built Crossfire that uses ALL Mercedes parts.
That, and I've driven many Hemi cars, and they are not even close in comparison to the SRT-6 on how they shift or act when driven.
Maybe someday I'll have to crawl under my cars out in the garage to find some part numbers.
Old Dec 4, 2006 | 07:27 AM
VQ35DE's Avatar
Fact. The parts manual is just one of several sources that state this.
Old Dec 4, 2006 | 11:26 AM
feets's Avatar
Would you believe that a 1999 ML 320 (V6 powered SUV) has the same tranny as a 2006 SL 65 (600+ hp roadster)?
Believe it!
You would never know by driving the two. However, the AMG cars will use different programming and in the case of the SL 65 they use a few different internals as well. Those internal differences are the reason they have different part numbers but they're all 722.6 transmissions.
My proof is in my Mercedes parts catalog.
Old Dec 4, 2006 | 06:49 PM
Wow... those are some seriously tough transmissions then.
Hmm... I'm beginning to contemplate a new drive line for my next hot rod project... hmm...
Old Dec 5, 2006 | 11:22 AM
feets's Avatar
I like them because they're small and take up very little room. I don't like them because they're completely computer controlled. It can't shift without the stinking computer.
Old Apr 3, 2007 | 10:16 AM
11SecS4's Avatar
It's also interesting to note that the SRT-6 and SRT-8 have the same exact gear ratios (1st through 5th and final drive). The SRT-8 comes with much taller tires from the factory though.
Old Apr 3, 2007 | 10:43 AM
AMGLover's Avatar
Deleted Message
Old Apr 3, 2007 | 12:58 PM
AMGLover's Avatar
Deleted Message
Old Apr 3, 2007 | 01:02 PM
11SecS4's Avatar
Yep, it's the same exact engine and transmission from the C32 AMG and SLK32 AMG. The only difference is the engine calibration and quite possibly the transmission software as well.
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
Ralph289
Sep 21, 2015 09:34 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
brandoni
Sep 6, 2015 07:35 PM
