IC pump
Old Oct 8, 2007 | 07:03 PM
cudaman's Avatar
Default Re: IC pump
subscribing, just for updates...
Old Oct 8, 2007 | 07:24 PM
maxxm's Avatar
Default Re: IC pump
Great idea, but FYI the email subscription notices haven't worked since the server changeover about a month ago. Hopefully that will be fixed soon, but you may still need to check manually for a while.
Old Oct 8, 2007 | 09:03 PM
boohooramblers's Avatar
Default Re: IC pump
Originally Posted by ShawnQ
I kind of caught this thread on the tail end...but I assume you all are upgrading to a more durable pump that is renowned by the AMG/MB guys?
Someone needs to make it 'plug -n- play'...
Is there a usual time when these stock bosch pumps fail? What causes the failure, the excessive heat?
SQ
If you pull apart the failed pumps, you'll notice a lot of carbon build-up and excessive wear on one side. The general consensus (I think!) is that the horizontal mount position for this pump is not optimal. It would probably last longer if it were mounted vertically - however, we just don't have the space in there to do that.
Old Oct 11, 2007 | 06:25 AM
DntXme's Avatar
Default Re: IC pump
My SRT ran out of power just this past Tuesday. No codes thrown, but I'm sure this is the problem. Anyway dealer agrees, but 14 days for replacement parts...
Old Oct 11, 2007 | 06:45 AM
RMADERMAN's Avatar
Default Re: IC pump
Only took two days for each SRT IC pump to be replaced once they decided to believe me that the lack of acceleration was due to the IC pump.
They were taken in one week apart. Now they both run great.
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
