Need pics of lowered SRTs with stock wheels
Old Feb 11, 2008 | 09:18 PM
cgocifer's Avatar
Default Need pics of lowered SRTs with stock wheels
Please post some pics of your lowered SRT with stock wheels. I've seen BrianBrave's, but would like to see some other colors and angles.
Thanks!
Old Feb 11, 2008 | 09:26 PM
msheredy's Avatar
Default Re: Need pics of lowered SRTs with stock wheels
My gallery has some.
Old Feb 11, 2008 | 09:30 PM
BrianBrave's Avatar
<--- Huge Horsepower
I like the comparison photo - Nice...
Old Feb 11, 2008 | 09:31 PM
maxxm's Avatar
And it looks really great, too! A very, very nice job.
Old Feb 11, 2008 | 09:49 PM
cgocifer's Avatar
Thanks, that looks nice!
Did you use Eibachs? Did you have to trim the bump stops? Use the stock shocks? Spring puller, or method outlined by BrianBrave in the tech area?
Old Feb 12, 2008 | 07:32 AM
JHM2K's Avatar
eracer76 has some nice shots as well...
Old Feb 12, 2008 | 10:05 AM
msheredy's Avatar
Thanks for the compliments. Yes I used the Eibachs. My car came with the number 3 spring pads in the rear and the number 2s in the front. I switched both front and rear pads to the number 1s (the thinest pads) for the maximum drop on the Eibachs.
I actually forgot to trim the bump stops so I will do that one day. Used the OEM shocks as well. I did spring (no pun intended) for a good Mercedes specific spring compressor. Here is a link to the set.
Spring Compressor
Old Feb 12, 2008 | 11:52 AM
ws6vert's Avatar
Looks great. Where did you get the pads from?
Old Feb 12, 2008 | 01:06 PM
msheredy's Avatar
I got them from Chrysler Parts Direct. They are under the front suspension and rear suspension sections.
Old Feb 12, 2008 | 04:18 PM
ShawnQ's Avatar
MSheredy...your car looks sharp!
Did you ever fab anything up for your center caps?
SQ
Old Feb 12, 2008 | 10:35 PM
msheredy's Avatar
SQ
Thanks! No I haven't. I was actually thinking about what MI1XFIRE said. I saw some AMG logo center caps on ebay but they are all located in Taiwan so I'm unable to "see" them in person to make sure the finishes are close. I may just end up getting a set and hoping for the best.
Old Feb 13, 2008 | 09:09 AM
smokey847's Avatar
msheredy,
Nice job. I have always been in love with they way that Eracer76's SRT looks:
Old Feb 13, 2008 | 02:10 PM
ws6vert's Avatar
I went to the site. How do you know if you are getting the number 1 pad, the tin one?
Old Feb 13, 2008 | 02:45 PM
Sidez's Avatar
Spring Compressor
I plan on lowering my car with the same set as your car looks great!! just wanted to ask the spring compressor is a tool for instalation correct? and also what pads are you talking about?
Old Feb 14, 2008 | 06:38 AM
cgocifer's Avatar
Thanks for the info and pics guys. I think I'm going to use the Eibachs with stock pads. I may use wheel spacers for the rears too.
Old Feb 14, 2008 | 09:53 AM
msheredy's Avatar
I got lucky I guess since there are 5 different part numbers for both front and rear.
Here is a list of part numbers from benzworld.
5mm= #1
9mm= #2
and so on.
You can tell which # you have by counting the dimples on the pads.
Old Feb 14, 2008 | 10:02 AM
msheredy's Avatar
The compressor is for both removal and installation. The first spring was a little tricky because my Dad and I had to get used to indexing the spring cups in order to actually get the spring out once it was compressed. Once that one was done they rest went smooth. Just make sure when installing the new springs that they are seated correctly in both the insulator and lower control arms. Otherwise you will get a crooked ride height.
The pads are spring insulators and go up inside the spring pockets in order to prevent metal to metal contact. They also serve as ride height adjustments too because of the different thicknesses offered. Attached is an exploded view showing the highlighted spring pad.
tom2112
Dec 1, 2015 09:02 AM
tom2112
Jul 28, 2015 08:12 AM
Blackout317
Jul 7, 2015 08:38 PM
turboomni08
Jul 7, 2015 11:48 AM
bradleykologek
Jul 6, 2015 02:49 PM
