At the track...
Originally Posted by distantpulse
No, I said F'it and just focused on the race.
Like I said last night, I personally think you have an air bubble in your line somewhere. Maybe I can swing down this weekend and we can see if we can find it...I'll see if I can steal (buy) some MB coolant from the dealer here...though I think at $20/quart I will sy unlikely.
Originally Posted by mrphotoman
Was your car hot from drivng to the track? I know my times suck if I do not let the car cool off for over an hour when I go
Wow those IAT temps are really high, with my meth setup on a 91 degree day with 90% humidity (our humidity is always crazy high here) my peak IAT running the car hard was 132 degrees if I recall correctly and that was after about 8 runs. I will have to check the datalogs when I get home. The other runs the IAT would go from 90 degrees to around 119 degrees which is great.
Was your car hot from drivng to the track? I know my times suck if I do not let the car cool off for over an hour when I go but then again it takes me 3.5 to 4 hours to get to the track (each way).
I am sure you will get it figured out soon, just hang in there!
Chris did you ever close the valve on the NW IC separator?
Btw, it was great meeting you Matt. It's cool seeing another 6 at Atco. Usually it's only me and Chris. Still you guys were some of the fastest "street" cars there last night. The only cars running faster were gutted race cars that were trailered in.
The 'what the hell was that' factor was in full effect last night...I gotta work on me RT though. damn .084 RT lost me the gamblers.
I feel like the new "Tom". Adding more parts and going slower. LMAO! Sorry man, I had to!! :P
I do have a serious queston though. Say there were air bubbles in the system that caused my high IAT's.....Would that cause the car to lean out?
Your IAT temps are high(er) because of the HE, they look very familiar to what mine were before upgrading to the supercooler. If you think there are air bubbles in the system, just open the valves on the iso system and drive around to get them out.
Originally Posted by SRT6 Gang Member
Nope.
Originally Posted by ZAHANMA
It is not simply because of the HE. I have the same HE, and would be willing to wager money my IATs are not that high...there has to be some other issue in conjunction...
::Edit:: Not trying to be a smart@ss, just speaking from exp. For whatever that is worth....
How much?
I will say I do not have manifolds or an intake on my car, so that may be adversely affecting things...just a thought. We were going to hook up Chris's iRev program or whatever its called to my car last night to get one run in with it, but 10pm came around and we got denied...
oh well, next time we will hook it up and see what the IATs are...cause now I'm curious.
the only thing I know is mine is definitely not falling flat on its face on the top end...so there has to be something different.
$.02? Cause its all anyone's opinion is worth, including mine.
The thought was to open the injectors more, still leaning at 5k rpm but not like distantpulse. Maybe, if you add fuel before 5K rpm you will not lean out as much on the top end, fuel pressure.......
::Edit:: Just becasue your car is not falling flat, doesn't mean your not leaning out on the top end either.
