My car hates the dragstrip!
Old Mar 21, 2008 | 06:44 PM
JFreed's Avatar
Default My car hates the dragstrip!
This car runs so good on the street but get to the track and all holy heck breaks loose, Needs wings c/a and pulley combo are the mods, 1,700 miles on odom. First pass 1.92 60', 12.87, no traction control on any passes, 2nd pass 1.89 60' 13.06 99.98 mph, lost 7 mph from previous pass, 3rd pass 2.12 60' 13.84 @ 88.6 mph car just lays down in 3rd gear, won't rev, last pass dash light comes on mid way down track esp? I can't remember exactly what it says pull out on the highway to go home and car is in limp mode! Pull over, shut it down restart, light goes out, car runs fine all the way home, pulls like a bear 1st, 2nd, 3rd all the way to 115 mph, is it possessed?
Old Mar 21, 2008 | 06:53 PM
bikecop's Avatar
Default Re: My car hates the dragstrip!
Sounds like maybe the i/c pump is going out from what I have read.
Old Mar 21, 2008 | 06:58 PM
JFreed's Avatar
I considered the ic pump, but i thoroughly flogged the car all the way home and ran fine.
Old Mar 21, 2008 | 07:05 PM
JFreed's Avatar
it was the bas/esp light and it seemed to put a rev limit of 5 grand?
Old Mar 21, 2008 | 07:08 PM
MD SRT6's Avatar
I know there are different thoughts on this but I believe on street tires you should leave with traction control on and manually shift before the esp has a chance to dive on you ie.. 5,800 rpm's or so as you have no more peak hp at any higher rpm anyway. I did this and ran a 12.7 with only a needswings and was pretty consistent.
Old Mar 21, 2008 | 07:16 PM
CdnX-fireOwner's Avatar
How hot was it that day and did you let the car cool down in between your runs...to me it sounds like you may have had an issue with heatsoak with the times getting lower and lower per run, but I am just basically quoting others on here who have more knowledge than I.
Old Mar 21, 2008 | 07:37 PM
JFreed's Avatar
70 degrees, at night, cooled between rounds as best i could with hood open.
Old Mar 21, 2008 | 08:00 PM
ChicagoX's Avatar
Sounds like intermittent pump failure.
Old Mar 21, 2008 | 08:37 PM
NeverEnough's Avatar
I'm gonna have to agree and say it is an intermitant IC Pump issue. Something is obvioulsy not right.
Old Mar 22, 2008 | 01:12 AM
freakingfastsrt6's Avatar
I have had the same problem from the past two pumps...IC PUMP IS YOUR DEMON! GET IT CHANGED AND LET HER RIP>>>>>
Old Mar 22, 2008 | 06:34 PM
H.K. Phooey's Avatar
Dry Ice on the IC between runs will amaze you.
mhajek18
Dec 30, 2015 03:40 PM
ultrajim49
17
Jun 27, 2015 12:20 AM
chturner
Jun 23, 2015 07:21 AM
pizzaguy
Jun 12, 2015 09:29 AM
pageoneresults
Sep 19, 2003 04:40 AM
