View Poll Results: Thoughts on the SRT grille emblem
I like it
52
85.25%
Not my cup of tea
14.75%
Voters: 61. You may not vote on this poll
"SRT" Grille Emblem
like it a lot sent u a pm about two sided tape,, i will do mine with the tape and see how it goes, thanks fot the info and idea. jim
I'll try to upload some pics today. I did not take step by step install pics, but I can write up a detailed instruction doc if needed.
From the front, it looks exactly like Gator's - same placement, etc.
The difference is that instead of adhesive, I affixed it with removable tape. I don't like to do anything to the car that I can't easily undo.
...and I don't want to cut my grille in anyway...
Quick how to and some pics of how I did it:
1. Order the emblem that is made for the Charger SRT, Challenger SRT, etc. (check with member sowardcustoms or eBay).
2. Break off or cut off the four tabs on the back of the emblem.
3. Use masking or painters tape to cover all of the parts you do not want coated.
4. Spray the back, sides, top, and bottom of the emblem with Plasti-Dip black spray (Home Depot has it) and let it dry. This will just keep the emblem from scratching the grill if any rubbing occurs.
5. Remove the front grill. Clean the slats that you want the emblem to mount to and the back of the dry emblem with rubbing alcohol or some sort of cleaner/adhesive promoter.
6. Adhere some of the 3M double sided foam super strength auto molding tape (Wal-Mart, Advance, etc. has it) to the back of the emblem where it will mount to the slats. Hold some firm pressure on it for a good while. I used little pressure clamps.
7. Peel the red backing off of the back side of the tape and stick the emblem on the grill. I used clamps to hold it tightly for a couple of hours or so.
8. Once I removed the clamps, I added two other bits of the tape as extra security from the back of the emblem to the side of each slat. Hold some pressure for a while to get good adhesion.
9. Check the emblem to make sure it is secure.
10. Reinstall grill and realize that it fits and looks great while questioning why the 300C SRT8 and the SRT6 didn't have them in the first place.
I have driven mine 3 days since I put the emblem on and it has not budged. However, if you do this and yours goes flying off, don't blame me.
Originally Posted by ZAHANMA
Thanks RPM...that is a great concise write-up...
I think I may hold off...performance first...
In case anybody is wondering, I think the price breakdown goes something like this:
1. Emblem + S/H = ~$38.00
2. Plasti-Dip Spray = ~$8.00
3. 3M Tape = $4.47
So, for ~$50 you have a new emblem and look.
Oh, and I hear the Dan R. will do a package deal including the emblem and installation for ~$1,400.00
RED DOG
44
Oct 27, 2020 09:00 PM
