I've got a transmission fluid leak
Old Oct 21, 2008 | 07:05 AM
ohnoesaz's Avatar
Default Re: I've got a transmission fluid leak
Well I was just curious why they would be messing with tranny lines in the first place? It has nothing at all to do with the repair, unless they were doing a full flush, which dealers won't do just to be nice.
It all seems suspicious.
Old Oct 21, 2008 | 08:10 AM
BLKFIN's Avatar
ADDICTED TO BOOST
You are right....odd stuff, but the Dealership just called and said it was fixed. On my way to retrieve it now~
Old Oct 21, 2008 | 09:05 AM
BLKFIN's Avatar
ADDICTED TO BOOST
I just back from getting the car. Just as a FYI the Invoice states part numbers 68021352-AA (Plug Adap 21003015) and 5097219-AA (Connector 21138013) and what I assume is 7 quarts of Transmission Fluid part number 5127382-AB ( Fluid Aut 1081033) .
Old Oct 21, 2008 | 11:12 PM
ohnoesaz's Avatar
Plug adapter and a connector? They may have replaced the electrical boot maybe.
The 7 quarts of tranny fluid is interesting... The pan only holds 4, and a leaking connector (due to its elevation) can only dump about 1 quart maybe. So if they put in 7 then they probably did some interesting things, like pull off the cooler line and drain that way, which explains the brass ring they needed to install it back again I guess.
I hope they filled the tranny fluid right.... My last dealer visit they did not fill it right, I had to add some with my dipstick+temperature-guessing. It shifts great now. Stupid dealer.
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
