Remove splash shield = dirt/grime = heat?
Old Aug 3, 2008 | 02:17 PM
ohnoesaz's Avatar
Default Remove splash shield = dirt/grime = heat?
I really want to remove my splash shield. I read the other thread where people said no problems. Here in Arizona, seems like a good idea to get rid of some heat.
But... Would the resulting increase in dirt and grime cause eventual heat buildup anyways? I look at how clean the engine stays and it seems like the splash shield does a lot in that area.
Old Aug 3, 2008 | 02:27 PM
70GT6's Avatar
Default Re: Remove splash shield = dirt/grime = heat?
Can not see there being a big benefit - unless you are racing and can open the hood to let the heat out - then I can see where having the bottom of the compartment open would help. But if you are driviing under normal situations all air movement is front to back and the belly pan is open at the rear.
Keep it clean and more important dry.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
atdavis2
Sep 21, 2015 01:25 PM
