Ordering a new pump: Johnson or Lightning-which is more reliable
Old Aug 31, 2008 | 10:02 AM
mrphotoman's Avatar
Default Ordering a new pump: Johnson or Lightning-which is more reliable
Before I spend the $ on a new pump, is there really a reliability difference between the LET motorsports Johnson CM30 pump and the Lightning/Bosch pump?
Anyone that has used the lightning pump, how many miles do you have on it and have you had any issues with it?
Old Aug 31, 2008 | 10:04 AM
Voyager's Avatar
Default Re: Ordering a new pump: Johnson or Lightning-which is more reliable
i havent heard anything with the lightning pump failing.
Old Aug 31, 2008 | 10:24 AM
cruzinquick's Avatar
Either pump is going to last, only difference is money and install.
Old Aug 31, 2008 | 10:39 AM
Voyager's Avatar
the let is a little more because it flows more. right?
Old Aug 31, 2008 | 10:42 AM
mrphotoman's Avatar
I have read that the lightning is the same pump as the OEM piece of crap pump. Does anyone know for sure if that is true?
Also, is LET still out of stock on the johnson pump?
Old Aug 31, 2008 | 10:45 AM
I'm sure it's priced pretty close, but there has to be some markup. The lightning pump is more common and that I believe brought the price down. More flow doesn't equal more hp.
Old Aug 31, 2008 | 10:48 AM
Yes it's almost identical that's why there is very little to do in order to swap it. The problem I've pointed to is everyone that the pumps have gone out have been cars that sat for a long period of time. Check the ford forums and see if anyone has changed out the bosch pump for a johnson?
Old Aug 31, 2008 | 10:52 AM
mrphotoman's Avatar
i thought the lightning pump required you to swap out the inlet/outlet from the old pump and the johnson was a direct swap?
Old Aug 31, 2008 | 11:02 AM
The lightning requires to swap tops and either get a ford plug or use spades to tap the wires. Stock bracket is used with no modifying. The johnson has different size inlet/outlet so a different hose or clamps are needed along with modifying the stock bracket that holds the pump. Wires connections pretty much the same as lightning pump.
Old Aug 31, 2008 | 11:11 AM
Voyager's Avatar
mine went out and mines is a daily driver
Old Aug 31, 2008 | 11:14 AM
mrphotoman's Avatar
Thanks for the info.
I may just go for the lightning pump and see what happens.
Old Aug 31, 2008 | 05:21 PM
dstuart's Avatar
Where can one buy a lightning pump at a good price? Thanks
Old Aug 31, 2008 | 07:57 PM
Here you go.
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old Aug 31, 2008 | 08:02 PM
Did you buy it new? As in 05' and been a daily driver since? I'm mainly talking about no original owners who drive their cars has reported one going out. My car only had 200 miles on it when I bought it, and the pump was fine. I just changed it to be sure. It did sit for over 2 years and needed a fuel pump and headlights. Even the wipers were shot. I suspect these pumps are going out from sitting too long without spinning or anything. Most have the magnetic propeller cracked.
Old Aug 31, 2008 | 09:39 PM
70GT6's Avatar
I am using the lightning pump. So far so good - can be had for less $80 to $90 (Johnson is $175)
After looking at the factory pump - which really appears to be a hefty design, I am beginning to feel the hose on the factory pump may be involved with the failure.
Only our pump (MB too of course) has a hose connected. I think this hose may be doing the opposite of its intended purpose. Instead of draining I think it may be an inlet for water - any car that sat for any length of time, especially during cold weather, would be damaged by water in the magnetic drive.
I am only guessing but when I took apart my failed factory pump the magent was cracked in half and the inside appeared "rusty"
The lightning pump does not have the connector for the hose - so just plug the hose when the pump is swapped.
These guys delivered quick: http://www.buyfordracing.com/shop/pr...id=580cPath=10
Old Aug 31, 2008 | 09:54 PM
mrphotoman's Avatar
Did it come with the harness?
Old Aug 31, 2008 | 09:57 PM
70GT6 saves the day below. nice job.
Old Aug 31, 2008 | 09:58 PM
70GT6's Avatar
no. I added wire to the factory harness. but if you want the harness you can get one on ebay or from Ford.
http://cgi.ebay.com/ebaymotors/Bosch...spagenameZWD1V
Old Aug 31, 2008 | 10:19 PM
mrphotoman's Avatar
it looks like a regular 5 cent spade connector would fit on the pump, has anyone tried that?
Old Aug 31, 2008 | 10:21 PM
70GT6's Avatar
They are very small spade connectors....can be done.
I just soldered the wires and black siliconed for water-tight seal.
