Supercharged Hood
Old Oct 25, 2008 | 06:15 AM
  #41 (permalink)
BLACKSRT-6's Avatar
Default Re: Supercharged Hood
Originally Posted by +fireamx
What exactly are the "vents" for?
To introduce cool air into the intake?
To place cold air "over" a heat exchanger?
To let "hot" air escape the engine bay?
Purely cosmetic?
I've never looked under the hood of any Mercedes, or Jag that had them so I really don't know there actual purpose.
Because if it's to introduce cool air into the intake, then it would probably not work as well as the factory design simply because there is at least 1" of "dead air" that envelopes the whole body of the car as it's moving. The vents would only allow the engine to "suck" cool outside air into the supercharger, as opposed to the stock design that actually offers some "ram air" effect.
As an exhaust vent, it would probably work just fine.
If it's purely cosmetic, then it boils down to what ever floats your boat.
True for a n/a car, a charger developes a negative pressure and benifits from the shortest run to cold air. I would move the vents nearer the windshield for the shortest run posible. I have the Code 3 intake filter, this design could easily be fitted to work well directing cool air straight to the supercharger. Actually, it would support the Code 3 filter if it did nothing more the vent off heat. It also looks much better with the lines of the crossfire then the AMX style hood, in my opinion.
Old Oct 25, 2008 | 06:16 AM
  #42 (permalink)
240M3SRT's Avatar
Originally Posted by BLACKSRT-6
Anyone else interested in an inexpensive functional hood!Thanks
Theres an oxymoron.
Old Oct 25, 2008 | 06:43 AM
  #43 (permalink)
+fireamx's Avatar
IMO, Your wheels look great.
Old Oct 25, 2008 | 06:48 AM
  #44 (permalink)
BLKFIN's Avatar
ADDICTED TO BOOST
The supercharged vents are an off the shelf product. Wouldn't it be cheaper to buy those and have them cut into the stock hood like we did in the old days? Has anyone placed the vents on a stock hood to see how they line up with the seams? If the vents cost $150, I know I could have them painted and installed locally for less then $200. Can we get some photos of the vents sitting on the stock hood in different locations that fit the lines of the hood? I think matching body color or silver matching the side vents would both look great.
Thanks
Do you have any idea of the part number?
Old Oct 25, 2008 | 07:31 AM
  #45 (permalink)
Squirrel Crusher's Avatar
Moparrbust could most likely help you share the part number for the supercharged vents. But beware. I cut a 12" round hole into my THICK steel hood of a 1967 stepside chevy truck because the hood wouldn't shut after installing a LS6-454 marine crate motor. Ended up installing a Trans Am scoop. After cutting the center spine for the hole,The hood was as ridgid as left over spegette. damn,how do you spell that word? I had to weld in extra bracing. If you dare to cut the hood,(Oh My Gosh)Don't cut any factory grooves or creases. Fiberglass hood! Think about it. Don
Old Oct 25, 2008 | 09:13 AM
  #46 (permalink)
BLACKSRT-6's Avatar
I have been searching but haven't found it yet. I may need to make a trip to a Jag dealer. I have post 2 questions to internet junk yards looking for a Supercharged XK with a smashed front. My guess is they will let the vents go cheap if the hood is trash. I don't plan to cut any braces, not my first hood chop!
Old Oct 25, 2008 | 06:30 PM
  #47 (permalink)
+fireamx's Avatar
I don't know how I missed this. But ironically the 2009 Supercharged Jaguar "XF" has a "ventless" hood.
http://www.motortrend.com/roadtests/...ged/index.html
I guess if ya got 4 doors, you don't need em.
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Charlesl
Sep 30, 2015 10:46 PM
waldig
Sep 17, 2015 10:35 AM
Vegaslegal
Sep 10, 2015 11:24 AM
