Tire Pressure
Old Jan 28, 2009 | 07:31 PM
jimboo's Avatar
Default Re: Tire Pressure
be Advised....the Higher The Tire Pressure, The Less The Contact Patch....just Look At Any Bike Tire To Verify...
Old Jan 29, 2009 | 07:47 PM
Kurts's Avatar
I put in what is printed on the label, which I am not sure, sitting in my house.
James
Exactamundo!
If the TPM light drives you nuts just fill 'em up when they're cold. If they still light up, they'll turn off as soon as the tires get warm.
Anyways, I hate getting out of the car in cold weather just to F around with the tires.
Old May 5, 2009 | 02:06 PM
frankiea5's Avatar
My dash tire pressure Light stays on after purchasing new tires??? I was told by the chrysler dealer that the 2005 crossfire TPMS callibration cost $80.00 ? Not under warranty??? The sensors are all working all tire pressure is good. The new Michlins were purchased and installed at Discount tire.Anyone heard of this before? $80 to calibrate the sensors?? The light won't shut off!!!
Old May 5, 2009 | 02:10 PM
facpro's Avatar
Try this thread!
https://www.crossfireforum.org/forum...highlight=tpms
Old May 7, 2009 | 07:42 AM
REVIT93RX7's Avatar
I run the recommended tire pressure that's on the sticker. They recommended those pressures for a reason. Safety first, now if running on a track than they will change but for street use it's what the manufacturer says.
Old May 7, 2009 | 09:56 AM
srt6_crossfire's Avatar
Would factory recommended psi still apply on non-OEM size after-market rims and tires that?
Old May 7, 2009 | 10:08 AM
mrphotoman's Avatar
275/35/19- 37.5psi
225/35/19- 33psi
Seems to feel the best to me when running hard in the curves, the car feels a little more balanced using those pressures.
Old May 7, 2009 | 10:29 AM
Tire pressure affects tire wear and grip, I have kept mine at 32/33 to 33/34 with a nitrogen fill (for what thats worth) topped up with air. The wear pattern is very even on the Conti's for 12,000 miles. Not many miles for an '04 but bad wear shows up quickly.
TerryR
Dec 13, 2019 03:27 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
lazorouss
Sep 11, 2015 09:16 AM
