Nice performance meter for only $29.95
Originally Posted by lacerdaschoon
I recieved my performance meter this morning and tested it out tonight. I have intake and sc pulley i just instaled this afternoon. I got 4.55 4.45 4.60 I did notice just before i reach 100ks (60m) on my speedo the run would end with the performance meter. Do these times sound right with the mods i have? I was very suprised didnt think i would be seeing such great numbers. Is 0-60miles and 0-100km slightly different? If so how would i calculate 0-100 maybe add on 0.1 - 0.2?
100kph=62.137mph roughly
assuming your would continue to accelerate at the same average rate for the next 2.137mph lol your 4.55sec run is roughly 4.71 seconds to 100kph and with a pulley and intake that sounds about right.
Originally Posted by faiz23
what did you guys use for conversion factor and weight,
i think coupe weighs 3100lbs and not sure about the conversion for loss from crank hp to wheel hp
I did the 1/4 three times and got a pb of 12.79. Keen to take off another couple tenths. I should be going to the track on wednesday for my very first run, i plan to use the accelerometer to compare.
got my toy yesterday but haven't had a chance to try it out. I am totally stock except a custom intake from AutoZone. It will be nice to have an estimate of what the car is capable of without having to take it to the track, which wife will not approve
VERY GOOD TIMES, for so few of mods.
Make sure on your weight. Is your gas tank full? Did you add your own weight? Maybe an Exs' body in the trunk?
Just checking if your paying attention.
Your guages out put data is only as acuarate as your weight input.
I have one of these and it is in my opinion BETTER than the G-tech. Also I have seen the Cat Matrix in catalogs
for as high as $199.00. So how great of deal is that?
I have recorded a 4.19, 0-60mph but I have a lot of mods and I have not matched that again. Too much wheel spin,
need to have just the right temperature.
HAS ANYONE HAD A 0-60 TIME THAT GOOD OR IS THIS THING GOING HAYWIRE?????
Mike
Mike
Hey Steve I think your missing a few factors there. Do you have ANYTHING IN THE GLOVE BOX? Really all the little things add weight. Most companies do not weigh their cars with a tank of gas,etc.
Mike
Mike
Mike
Mike
montana brought up a good point that I didn't mention regarding extra weight. I personally rounded up 3,500 to include my weight, gas, and small tool box in the back. My problem is that in order to test it and not get the cops called on me, or pulled over, I need to drive 20-30minutes away out into the sticks. NY cops have been relentless with tickets lately, my girlfriend knows first hand. 2 in 2 months.
Has anyone tried a different "correction factor" other than the factory 1.0, and proved the results?
Just curious, Steve.
Guess I leave correction factor at 1 (factory default). Also Ive set the min hp to 30 and the max to 70mph...any suggestions about this also? . Manual says weight 3100 lbs, im 150 lbs...tank of gas 98 lbs
BTW..its an 04 n/a with magnaflow and TVT cai
Originally Posted by mrphotoman
Very similar performance to the gtech pro i used to have only this costs $29 on clearance!
Tried it tonight on the hhr ss and it showed 14.65@97mph which is right where it should be. I actually like it better than the gtech because it is wireless and compact.
Here is where I got it, a fun little toy to have and they are pretty darn accurate, i have used these accelerometers at the track several times and they are within 1/10th of second typically.
You better grab one before they sell out.
K.A.T. Matrix 3-Axis Accelerometer (Car Performance Meter) K.A.T. Inc. MATRIX
I can take a vid tomorrow if anyone wants to see it being used.
saw listed for about $150 in a magazine not too long ago. What a deal! Thanks again.
Coyote
ok i always wanted one of these so i picked one up on ebay for $32. i have a stock na roadster. i set the weight for 3500. left the rest default. i was on a slight decline so i know that helped my times a little but here's what i got:
1/4 mile:
97 mph
14.87 second
135 hp
154 hp
0-60:
6.34 second
141 hp
161 hp
There are a few things i'd like to change about this unit. i wish you can do 1 run and get both 1/4 mile times as well as 0-60. the other thing i'd like is if it would store max g forces in memory. i doubt very much i'd be rounding a turn and looking at the meter to see my max g force.
1/4 mile:
97 mph
14.87 second
135 hp
154 hp
0-60:
6.34 second
141 hp
161 hp
I'd say very accurate
My track times with the Needwings intake were 1/4 mile 14.78 and 99mph with my 2004 Coupe last summer.
The best of 22 runs.
I got one of these meters last week but have not tried it yet.
I'll post the results here and use your settings for my run.
You shouldn't have to input an accurate weight to get accurate acceleration times. The weight input is only needed for accurate calcuation of HP. Otherwise, the accelerometers in these devices use g-forces and time to determine 0-60 and 1/4 mile times - that's all they need. Xg for x.xx seconds will determine all that because weight does not factor in. For example, 3g is 3g no matter if you're in 2,000lb car or 5,000lb car. But it takes a lot more HP to sustain that 3g in a 5,000lb car than it does in a 2,000lb car, so if you want an accurate HP calculation done, you need an accurate weight.
I have a similar device, a Belltronics Vector, and it always gave me times very close to my time slips at the track, usually within a tenth of what the time slip read for a given run (yeah, I'd have the thing running at the strip).
You will notice a couple of minor differences between one of these and a track time slip, for a couple of reasons:
1. The track time slip is based off the timing lights, obviously, which means it doesn't start timing until you've broken out of BOTH staging lights so it can vary just a touch depending on whether you deep stage or not. An accelerometer starts timing the instant the vehicles moves
2. The track time slip trap speeds are calculated from the two sets of trap lights at the top end of the track - normally 20 meters or 66 feet apart. The accelerometer gives you a "trap speed" calculated at the very end of the 1/4 mile, so if you're still pulling hard in those last 20 meters the accelerometer will show a higher trap speed than the official time slip will.
Interesting points Mike. Valk has one of these and brought it out to US41 last weekend. I didnt even think about the weight only coming into play when determining HP...wasn't really focused on it at the time...
P.S. on a side note: I was once at a drag strip (as a spectator) and saw two guys come to punches over one guy deep staging and the otehr guy thought it was poor sportsmanship, blah blah blah...needless to say, the guy who didn't deep stage lost the race, and then proceeded to get his a** whipped by the guy he picked a fight with...
all in all quite amusing
Originally Posted by Mike-In-Orange
...depending on whether you deep stage or not.
Great find, When I saw this thread come up I bought one right away. I just got around to trying it out, Easy to operate and seems dead on accurate + I love the fact that it is wireless!
Thanks Mr. Photoman,
Just ordered one today, Hope their not out....
Thanx for the info Mr.P...
I received mine yesterday and did some (actually only four) runs today:
1/4 mile:
95 mph
14.90 sec.
136 hp
153 hp
0-60 mph
6.64 sec.
132 hp
150 hp
I left everything on factory default and set the weight to 3500 lbs. The street was veeery slightly uphill though. And I forgot to turn the TC off.
So I'll definetly will do some more runs in the next days because there should be some room for improvement.
Performance mods on my car (btw: it's an Autostick): CLK-Airbox with large Airducts and K&N-Filters, 74mm-Throttlebody - still stock exhaust and no tune/Injectors
1/4 mile:
95 mph
14.90 sec.
136 hp
153 hp
0-60 mph
6.64 sec.
132 hp
150 hp
So I'll definetly will do some more runs in the next days because there should be some room for improvement.Performance mods on my car (btw: it's an Autostick): CLK-Airbox with large Airducts and K&N-Filters, 74mm-Throttlebody - still stock exhaust and no tune/Injectors
