Question for those in the know. Just installing Code 3 pulley and CAI?
Old Jun 2, 2009 | 01:20 PM
KnappAttack's Avatar
Default Question for those in the know. Just installing Code 3 pulley and CAI?
So if I just install the Code 3 supercharger pulley and cold air intake, will I have to install a tune to prevent engine damage? I don't have, nor do I want to add any A/F gauges. I want a sleeper roadster I can drive everyday. Eventually it willl get the Johnson pump also.
I was also thinking about porting, (gasket matching) the stock manifolds and Y pipe. What effect will this have on A/F ratio using stock ECU?
Am I making a mistake doing any of it? I don't want issues!
Thanks for your help, Mike
Old Jun 2, 2009 | 01:29 PM
Thumper SRT6's Avatar
Default Re: Question for those in the know. Just installing Code 3 pulley and CAI?
You don't NEED a tune with just the Code3 pulley and a CAI. I ran that exact setup for months with no issues (including many trips to the dragstrip).
Old Jun 2, 2009 | 01:34 PM
XfireBlake's Avatar
I put on the code 3 pulley and Code 3 intake 2 months ago and still commute with it. I took it to a 1/8th mile track and pulled 8.1 seconds at 88mph with OE all season tires! You don't need any more parts but heat soak can be a problem on hottest days. I will have to build a needwings style intake to help.
P.S. I have full set of SRT-6 wheel 4 sale if anyone wants them!
Old Jun 2, 2009 | 01:52 PM
SRT6-Man's Avatar
You should be fine, your computer will make the adjustments, after some time on the road!
Old Jun 2, 2009 | 01:59 PM
ACRucrazy's Avatar
The computer should be able to handle the pulley and CAI just fine.
I would guess porting the y pipe and intake manis would not yeild any results to make it worth your time.
Old Jun 2, 2009 | 02:12 PM
waldig's Avatar
Talking Re: Question for those in the know. Just installing Code 3 pulley and CAI?
I have done all the above with great gains. I did the gasket matching on the heads and intake manifolds along with LET thermal spacers and felt better responce. My first dyno was over 300 h/p though I dont remember right now.
The Cai does little to the F/A and the code 3 gave me up to about 17 PSIG AT THE MANIFOLD, not the wye which is artifically higher due to friction losses in the intake piping , especially the factory manifolds. This is why the needswings and 240xxxx manifolds flow so much better.
Bottom line, it will be great and do just fine. You can check my threads under my earlier account "Woody Woodworth" for the how to of the port matching of heads and intake. Enjoy, Woody
gblack32
Sep 7, 2016 08:27 PM
tom2112
Oct 26, 2015 08:18 PM
PNA
Crossfire Events and Meets
Jul 13, 2015 11:40 AM
bdh
Jul 9, 2015 09:40 AM
bradleykologek
Jul 6, 2015 02:49 PM
