expansion tank
Old Aug 5, 2009 | 01:37 PM
goodgenes79's Avatar
Default expansion tank
I have broken the nipple off the top of my tank and epoxy and jb weld won't seal it properly soooo.. I need a new tank and thought I would buy the smaller tank found in the C32, got it home and it is for the driver side so will not fit. Does anyone know where I can find an expansion tank that fits and works? I really don't want to pay $80+ for a plastic tank but just might have to bite the bulley. I am running the seperation lines if that helps, so if anyone has any idea of making the C32 work then greatly appreciated. Ideas or sites welcome. thanks
Old Aug 5, 2009 | 02:27 PM
jturkel's Avatar
Default Re: expansion tank
Recovery Tanks
Old Aug 5, 2009 | 03:20 PM
waldig's Avatar
Talking Re: expansion tank
jb not working?
Did you wash area with acetone first?
Roughen area to give bond a tooth to grab on to.
Woody
Old Aug 5, 2009 | 09:43 PM
BrianBrave's Avatar
<--- Huge Horsepower
One of these?
Old Aug 6, 2009 | 01:42 AM
ProjectMayhem's Avatar
I did the same thing i broke the nipple off when i was seperating my lines, JB worked for me like woody said clean the area well and give the jb weld time to set and it should work just fine. Ultimately switching to a flow tank that holds about the same amount of collant instead of just an overlflow tank, that will allow me to drop ice in for when im drag racing.
Old Aug 10, 2009 | 11:17 AM
well I have to admit I initially used cold steel puddy that didn't adhere well. I got some REAL jb weld kwik set and it seems to have worked alot better. I put it on this weekend and let it set and no leaks as of yet. I guess it pays to use the good stuff. Thanks for everyones help and suggestions. I will probably go with an aftermarket setup when I get a new intercooler, properly seperating the fluids with there own tank.
While I was fixing things I put the DIY belt wrap kit and dual CAI's on and WOW did it make a difference. I think I am set for awhile until I can afford new I/C and tune.
Cheers
Old Aug 10, 2009 | 04:42 PM
32krazy!'s Avatar
Cheers
are you running stock pullies? when you did the belt wrap did you have any issues with the tensioner being to tight to wrap the belt?
being from huntsville you should check out the car show in the boro every fri. evening. upwards of 200 cars and 2 months ago 700 showed up. good time and place to show off the car!
Old Aug 10, 2009 | 04:53 PM
For whatever reason my signature didn't show up. I am running Code3 so not stock, had no problems. I was getting some crazy belt slippage before with black soot all over pulleys. I put belt wrap on and realized just how much I was loosing in power. It really feels like a rocket now.
I will definitely have to swing up there for a Friday night, send me a PM on where exactly.
Old Aug 10, 2009 | 05:29 PM
32krazy!'s Avatar
i tried the wrap with the stock setup and it wont work. im guessing the difference in pulley size is what allows the wrap to work. if i can ever find some one with the c3 for sale and actually sticks to the deal ill get 1
the Avenue mall in the belk's parking lot. 1$ donation runs till 9pm or so. i always park in the lot with all the vettes. they really needed someone to class the group up!!! theres anaother member here from lynchburg also. i emailed him but never got a response
paine2907
Oct 2, 2015 10:01 AM
pioneer4x4
Aug 9, 2015 08:15 AM
Ralph289
Jul 26, 2015 12:52 PM
SuperD500
Jul 23, 2015 02:53 PM
ja.nko
Jul 10, 2015 03:21 PM
