New belt! slower ET and Trap
Old Sep 15, 2009 | 04:38 AM
ProjectMayhem's Avatar
Default New belt! slower ET and Trap
Like the title says put a new belt on since the stock one crapped out on me. After my Eurocharged tune i had some great passes with a 12.08 @ 114.8 as the best of two runs that night after the new tune.
Well i went to the track again next week and ran 2 passes a 12.5@ 109 and 12.4@110... I assumed my belt had died and sure enough there wasn't much left of it when i took a closer inspection.
Put a new belt on and still had some strange times, 12.3@110 and and 12.2@111, which i know doesn't sound bad but these are not typical times for my car. Normally when i get 12.2-3 times its 112-113.8 traps before i even got the tune.
I borrowed a friends datalogger to watch the manifold air pressure on a 3rd gear run from 2500rpms-redline and the new belt shows a steady increase in manifold air pressure all the way till redline so i'm positive there is NO slip with this new belt on. No visual signs of belt slip either.
I'm curious what other think of this.
My two thoughts are 1. that when i got the eurcharged tune with the stock worn belt i was slipping some and putting this new belt on is throwing that tune off.
2. Some how doing a few runs with the belt slipping majorly threw something out of wack with the tune and needs to be adjusted?
I'm more inclined to think its the first because that means i got even more power to squeeze out of her
Jerry or Tony if you see this give me a ring left some voicemails!
Old Sep 15, 2009 | 08:32 AM
TVT_DESIGN
Guest
Posts: n/a
Default Re: New belt! slower ET and Trap
They only way the belt would've altered how your car was tuned was if it was on a dyno. I'm pretty sure they don't tune to take in to account belt slippage. I might be more mechanical based.
Old Sep 15, 2009 | 08:42 AM
I don't think the belt could change .4 on your time, or the mph,, but if your belt is now slipping it would change your ET and MPH,, go do it again this time carry some belt lube with you spray it 4 times only on the web side and two times on the smooth side ( one time = pazzee just one quick spray), maybe your data log was low , unless you have one to compare it to,.jim
Old Sep 15, 2009 | 09:29 AM
ZAHANMA's Avatar
email greg@eurocharged.com
he is the fastest contact for eurocharged and they can give you their thoughts on it.
...and correct me if i'm wrong, but you went up to eurocharged to get a full dynotune did you not? so there could be something funky with the tune because of the belt slip.
Old Sep 15, 2009 | 09:42 AM
tighed1's Avatar
Sounds like you have a case of the "Tom".
https://www.crossfireforum.org/forum...-slower-2.html
Old Sep 15, 2009 | 09:50 AM
distantpulse's Avatar
12.3 @ 109-110 = LEAN up in the top gears. I would like to see the timeslip. You are probably really quick through the 1/8mile, then the car falls flat up top? You are probably leaning out at the top of 3rd and 4th gear due to the belt NOT slipping. It could have been slipping when they dyno tuned your car? Now its producing more boost, but not enough fuel to feed up top. Just some thoughts.......
Old Sep 15, 2009 | 04:01 PM
this is what I was thinking distant because to achieve this ET you normally have slightly higher traps speeds, yes there was grime and belt dust on the supercharger while it was getting tuned someone made the comment that my belt looks like it might be slipping but the car pulled like a raped ape on the dyno and the track after the tune.
Old Sep 15, 2009 | 04:07 PM
Yes I did i had the Graphite srt6 and the other two guys had limited's. Looks like i will end up having to do that 4 hour drive again from STL .
Old Sep 15, 2009 | 04:09 PM
Yeah, right now im even running very lean at 113mph traps @ around 12.1-12.2. My ECU is getting re-tuned by Eurocharged/LET as we speak so hopefully we will see a difference. I assume you don't have a wideband A/F gauge?? The one thing I would suggest to ANYONE that mods, is to get a A/F gauge in there at the very least.
Old Sep 15, 2009 | 11:59 PM
Nope widebandless (new word). Well i went to the track again tonight thinking maybe it was a fluke. Well i was again hit with 12.2-.3 ETs again with 110-111 traps. Now here is the interesting thing on my third run i ran outa gas and the lowest they have at the track 100 octane. I figured if im running lean this wont hurt. Well i ran a 12.08@113.95... which was very comparable to my run the night after driving home with the new tune.
Old Sep 16, 2009 | 05:42 AM
Mimi05SRT6's Avatar
We all are going through what you have. My best all summer was mid 12's, compared to my 12.1. Track conditions (weather) has a lot to do with it. Cooler temps will get you right back where you were. Our cars really love heat soak this time of year. Be patient, I know I am and can't wait for those cooler temps and better DA's right around the corner!
Old Sep 16, 2009 | 06:23 AM
waldig's Avatar
Lightbulb Re: New belt! slower ET and Trap
Ugh, not belt lube...............................Belt dressing. You dont want to do anything that may slip the belt, it will burn up.
The weather is changing and the cooler weather can lean you some. Boost your fuel pressure to correct this but you must know the f/a. I have two sensors and they are not in agreement at times, one is slower than the other it seems.
Woody
Old Sep 16, 2009 | 08:40 AM
What octane do you usually run? It makes sense that it would pick up. It's probably not retarding the timing as much with the 100. You are still more than likely running lean up top. I would get your tune fixed ASAP.
Old Sep 16, 2009 | 09:38 AM
Bullseye's Avatar
How was the weather your best run and the new runs? While it is forced inducted, d/a will still affect it.
Old Sep 16, 2009 | 02:17 PM
93 and it was tuned under 93 as well. But the point of trying the 100 octane was to see if i got extra time. Higher octane doesn't give you a lower ET unless your tuned for it or in my situation your losing timing from leaner conditions up top. .2 sec is massive. Yes i have taken DA into account these last two tuesday nights with the new belt have been better DA than my previous best after the tune. Plain and simple i think i have narrowed it down i just need to get the thing retuned from only a damn belt change =P
Lesson of the story get your car tuned with a good belt on the car!
Old Sep 16, 2009 | 03:39 PM
tom2112's Avatar
She can ride with me ;)
OUCH! That hurts.
:P
Old Sep 16, 2009 | 03:58 PM
Originally Posted by tom2112
OUCH! That hurts.
:P
Don't give up there Tom Boy. We'll get you to the promise land eventually.
Old Sep 16, 2009 | 04:12 PM
tom2112's Avatar
I'm starting to think it's the driver. But... my trap speeds are a bit low for what I should be getting. I dunno. I gave up a while back and decided to just drive the hell out of it and enjoy what I've got.
Old Sep 17, 2009 | 12:07 PM
cruzinquick's Avatar
Take the guessing out of it and datalog. Has to be one of the first mods if your going to run it hard. At least for the safety of your car.
Old Sep 17, 2009 | 12:15 PM
tighed1's Avatar
Evan what are you using to datalog with?
