Squeaky engine noise?
Old Oct 4, 2009 | 12:36 AM
mr-lama's Avatar
Default Squeaky engine noise?
My srt6 just started having a slight squeak in the engine. It sounds like it's towards the very front, around the belt area. It sounds like it's mostly at low rpm's, and goes away at anything above that.
I haven't noticed any power loss though. Everything seems to be working fine, no heat problems or anything. Just a squeak, but an annoying one.
It's getting cold here at night, maybe it just caught a cold?
Old Oct 4, 2009 | 02:12 AM
tighed1's Avatar
Default Re: Squeaky engine noise?
Sounds like you have a bearing that's wanting to go bad. Time to get the hose out and trace which one it is.
Old Oct 4, 2009 | 01:26 PM
PA/XFIRE's Avatar
Are you running stock ? If not what modifications are you running ?I had a similar noise when i was running stacked pulleys and the code 3 wrap kit. When i removed the midsize c3 pulley and and removed the c3 wrap kit and replaced it with the needswings pulley saver kit the squeak dissapeared.It
seemed when the s/c kicked in thats when i heard the noise then it would dissapear.It had to be one of the three c3 pulleys bearings starting to go.I
would use the woodyscope test on your pulleys. Good luck finding the source
of the problem. ILLCYA
Old Oct 4, 2009 | 01:38 PM
mr-lama's Avatar
It's all stock except for a DIY code 3 intake.
What exactly do I do with the hose. I searched and found another post, but it wasn't very specific, and this kid needs specifics. I know I hold one side to my ear and check.... what?
And just assuming it is a bearing, how much do those cost to replace? And are they usually covered under a powertrain warranty?
Old Oct 4, 2009 | 02:01 PM
32krazy!'s Avatar
it depends on the bearing. s/c pulley bearing 56$, idler pulleys replaced as a unit 20$ tensioner pulley also replaced as a unit 40$
now a/c alternator water pump bearings get into a whole nother price range!
for me when i did my c3 swap the s/c pulley bearing 2 idler bearing and tensioner puleey all showed signs of bearing wear so i replaced them all. total cost was under 150$ or so.
its just not worth risking a bearing failure and the thought of a broken pulley ping-ponging around the front of the engine just hurts!
Old Oct 4, 2009 | 02:34 PM
tighed1's Avatar
Hold one end of the hose to your ear. The other end you move around the area that you hear the noise coming from. Start at one bearing then move to the next till you figure out which one (or thing) is making the noise. The noise will become louder as you get closer to it.
NOTE: Be VERY careful as there are moving things (belt, pulleys) that want to grab the hose out of yer hand!
Old Oct 4, 2009 | 05:36 PM
mr-lama's Avatar
Well, the noise stopped.
Got in this morning to pick up a friend, and it wasn't making any unusual noises. Drove it around several more times, still no noise.
Should I still be worried? I mean, I can't check with the hose thing now, it's not making the noise. I'll obviously listen out for it to come back, but it's been gone all day.
Anything I should check still?
Old Oct 4, 2009 | 07:11 PM
tighed1's Avatar
You may not be able to hear it over the engine noise but may still be able to hear something with the hose. Listen for a grinding sound.
Couldn't hurt to check.
Old Oct 7, 2009 | 12:44 PM
REVIT93RX7's Avatar
I would suspect the Idler pulley bearing.
Old Oct 8, 2009 | 01:45 PM
tighed1's Avatar
Sure wish folks would report back after they ask for assistance.
Someone may encounter the same problem down the road and this could help them.
Old Oct 8, 2009 | 04:25 PM
mr-lama's Avatar
Sorry I hadn't said anything back.
It stopped making the noise, and I haven't been able to hear it since. Hose trick and all. Just stopped.
Old Oct 9, 2009 | 01:04 AM
tighed1's Avatar
Well at least you will be ready for next time!
Thanks for checkin' back in. We were getting worried!
Old Oct 9, 2009 | 03:00 PM
mr-lama's Avatar
Well geez, you don't have to wish bad luck on me that this will happen again!
Old Oct 24, 2009 | 12:24 AM
jonnyangel04's Avatar
I dont think it is a bearing at all.... I have the same problem at really low rpm take off almost like a high pitched chirp when your not getting on it. It is the clutch on the supercharger there have been numerous post about this on MB world I just cant seem to find them. Guys were freaking out taking there cars in and mercedes was replacing the whole supercharger because there was no way to order just the clutch assembly. With that being said when they got tired of replacing superchargers they started lubing the clutch. I will keep looking YTD i think there is no fix, but it wasnt as major as everyone thought.
Rudy chime in do you remember this?
Old Oct 24, 2009 | 12:37 AM
found it, still no answer but John is on the problem, this problem has been around for awhile. I am thinking a NW pulley saver kit, and an NSK bearing should do the trick.
From Jerk to Chirp, the saga... - Page 2 - MBWorld.org Forums
unplug the supercharger clutch drive around see if the noise goes away. If it does you have your clutch engaging answer. Mine does not do it all the time so i have no way of really checking. Yours sounds pretty often I would think this would work for you.
Old Oct 24, 2009 | 09:22 AM
mr-lama's Avatar
It's definitely not that. I get that noise all the time, just like you said, when pushing the gas pedal but not pushing hard. Screechy noise. Kind of annoying, but I got used to it.
This noise was different. It was only audible at idle and just over. It was a completely different noise than the SC screechy noise. As far as I know, the screechy SC thing isn't a problem right? Just an annoyance.
Old Oct 24, 2009 | 08:24 PM
The jury is still out lol
Old Oct 25, 2009 | 08:25 PM
Bubba89's Avatar
I had the exact same thing happen to me as described in the MBWorld forum when I had my 178 pulley and my code3 installed coupled with the tune from Eurocharged. After a bunch of troubleshooting that did nothing i ended up requesting a new tune and it fixed the jerking problem. I was relieved the heavy jerk was gone but soonthereafter the chirp that the guys on the mb forum described started in. That lasted for about a month and just vanished randomly. Its very weird. I even had TVT check it out and he wasnt sure what was going on, suggested that it might be a failing pulley or belt slip. Havent had any problems since though. I also installed the DIY beltwrap kit installed in the process of troubleshooting, which I thought was putting too much pressure on my pullies but idk its stil on and the problem went away so I'm gonna leave it alone. Just thought I'd share
Brandon
Old Nov 14, 2009 | 06:26 PM
mr-lama's Avatar
Ok, squeaky noise came back. It seems to want to go away when it's warmed up so it's hard to get to look at unless I go out and start up the car just to check.
I did that today though, and it sounds like it is coming from the pulley just low left of the SC pulley. It's a smooth one. The guy at the shop I went to so he could check it out said he wasn't sure if it was a pulley or it was just the belt being too "glazed" and sliding around on it until it got warm. Does this sound like a possibility or is it still probably the bearings?
I did go by oreilly's to look at the new stuff. They looked it up and it was 200+ bucks for that pulley (I think it also had the mounting bracket on it), which is a LOT. So for you guys that have the knowledge, do I need to replace the whole pulley, or can I just get the bearings and put them in there?
And where would you recommend I order whatever part I need from to keep the cost down?
Old Nov 14, 2009 | 07:01 PM
MikeR's Avatar
It sounds like your talking about the idler pulley. No way it costs $200.. you can get it from MB for about $70 I think, or you can get a Gates equivilant for about $20 or so. One bolt to pull, slap in the new pulley and re-install the bolt with blue loctite and torque to spec.
