Check Transmission Fluid?!?
Old Nov 6, 2009 | 05:45 PM
NeedsWings's Avatar
Default Re: Check Transmission Fluid?!?
Originally Posted by tom2112
Thanks! I ordered one yesterday. $30 compared to $75 isn't bad. I still think they should include something like this with the friggin car. "No maintenance required" my butt. LOL
ill be doing my trans service in the next week or so myself at 37k, ill see how in depth it is and do a write up
Old Nov 6, 2009 | 08:31 PM
Squirrel Crusher's Avatar
Originally Posted by 32krazy!
Just ordered....Thanks...Squirrel Crusher
Old Nov 6, 2009 | 09:02 PM
32krazy!'s Avatar
did mine at 40k. no issues at all . if you do like i did and forget to put the magnet back in the pan you get twice the practice!! the bolts that hold the pan on and the rubber gasket can be a little tricky, remember to snug all the bolts a bit before tightening to keep from pinching the gasket.
also i broke loose the trans line at the rubber to hard line connection and put it in a jug. started the car and went thru all the gears which took 5 sec? drain most of the fluid out of the t/c. refilled and basically had a full flush
while doing this i suggest you go ahead and replace the tranny plug elec. connector that has a habit of going bad. no need for tranny oil to run down your arms twice!!!
Abaton6
Oct 26, 2016 10:43 AM
velociabstract
15
Sep 7, 2015 03:43 PM
sittininthesun
Aug 24, 2015 10:47 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
chturner
Jul 24, 2015 04:47 PM
