I freaking HATE this traction control
Old Dec 29, 2009 | 10:09 PM
KrzyFast's Avatar
Default Re: I freaking HATE this traction control
Originally Posted by RIOT
Shift To First And Hold The Lever There....
Huh???? was does that do?
Old Dec 29, 2009 | 10:43 PM
It holds the tranny in first gear until maximum RPMs.
It will hold it in every gear to max RPMs all the way up if the track you are running is long enough.
Or you can let it go up as you approach whtever max shift points you like up to redline. Just relalease the shifter right a sec, pull left and hold to next shift point.
Depending on your tune and mods;
Pedal to the floor puts you in triple digits in or near the quartermile. Should be in fourth by then.
Be sure the road in front of you is long enough.
If you haven't been doing this before you were driving the equivalent of an expensive NA.
Once you get the hang of this tranny you won't believe what you were missing.
Now, enjoy your new car.
roadster with a stick
BTW, You might go ahead and read this part of the manual also. Just don't tell anybody and your pride is safe.
Old Dec 30, 2009 | 02:30 PM
billvp's Avatar
I read the manual, and I don't remember anything about having to hold the lever to the left.
The detail about it staying in the same gear until redline, etc. works also if you push the lever to the left twice quickly (or a few times slowly) until it goes into 1st ... then release it to the center again. Is there something else I'm missing?
Old Dec 30, 2009 | 02:49 PM
mr-lama's Avatar
That's what I though, you drop it into first (or the minimum gear for your current speed) and just let it go back to center and leave it alone. That will keep you in gear until you redline. Or so I thought. Have I been doing it wrong?
Old Dec 30, 2009 | 03:20 PM
RIOT's Avatar
Yes you can put it in first....but it won't always stay there.....hold it all the way to the left after you put it in first.....try it you might like it....
Put it in first punch it a lil...let off the gas and look down...it will shift up even though ya only goosed it a lil...but if ya old the lever to the left goose it a lil and wow it stays in first.....thats how I can play with the throttle smoking the tires and....well you figure it out just try it.
Old Dec 30, 2009 | 04:08 PM
billvp's Avatar
I've looked plenty of times, and it doesn't upshift in any of the gears when I take off from a start ... it'll be sitting at 5000+ rpm if I just floor it from a stop and then let off a little. I'll try it out again though later this afternoon if the rain holds off .
Old Dec 30, 2009 | 04:22 PM
klong's Avatar
Originally Posted by TemjinX2
when you push the off button...its not a complete off. Its like a traction control sport. Its off until the computer thinks your gonna die and turns back on. There's no way to completely turn off esp unless you pull the fuse or go into dyno mode.
Last time I tried that, the traction control in the passenger seat started beating me at about the same time the rear end went by; pretty effective, but you can't turn it off.
KevinL
NoVA
Old Dec 30, 2009 | 05:37 PM
dejohnny's Avatar
Originally Posted by Holycrap
Ok the weather is finally cool here in south florida. So i took the srt out to do some spirited driving. Welllll at any rpm in first gear the damn traction controll takes over and i literally hit a wall and sometimes shortshifts the hell outta the car. Ive asked this question before without an answer. And the search feature here sucks!!! How do i permanently disable traction controll? Im tired of traction Control spoiling all the fun!
Also when it does hook up (usually warmer weather) is it supposed to short shift into second?? (5700-5800) when in D. Thanks again
Maybe your car is too DAMM Powerful!
Old Dec 30, 2009 | 05:54 PM
waldig's Avatar
Talking Re: I freaking HATE this traction control
I do autocrossing with the t/c OFF always. Never an issue for me. I have even cut into the Yaw sensor and added a switch to disable it 100%.
Spinning, I use 275's on the rear AND I USE THE LSD by phantomgrip, its a difference you can live with. Enjoy the new year and LONG WEEKEND.
WOODY
Old Dec 31, 2009 | 09:53 PM
Chris L.'s Avatar
KevinL
NoVA
Candidate for best post ever!
syfi
Mar 28, 2026 04:14 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
