Anyone have the code3 Belt Wrap kit instructions?
Old Feb 11, 2010 | 10:37 PM
billvp's Avatar
Default Anyone have the code3 Belt Wrap kit instructions?
I'd like to see what they say to use from stock, etc.
Anyone have a file hanging around from a while back?
Old Feb 11, 2010 | 10:51 PM
tighed1's Avatar
Default Re: Anyone have the code3 Belt Wrap kit instructions?
You could always make ter own.
Someone did a pretty cool (and cheap) DIY somewhere around here.
Old Feb 11, 2010 | 10:52 PM
billvp's Avatar
Yeah, I know ... wonder who that was
Old Feb 12, 2010 | 04:47 PM
32krazy!'s Avatar
hang tight billvp. i have something in the works with needswings which will make all the c3 guys jump for joy!
Old Feb 12, 2010 | 04:54 PM
I am getting too old to jump, but I am interested...lol
Old Feb 14, 2010 | 07:27 AM
lacerdaschoon's Avatar
Keen what is it? how long?!
Old Feb 14, 2010 | 07:41 AM
velociabstract's Avatar
I'm all ears! I don't see any signs of belt slippage but I could be happening an I just don't know it.
Les
Old Feb 14, 2010 | 07:45 AM
won't really know it without gauges to assist you..
Old Feb 14, 2010 | 08:04 AM
I have a Dashdaq and have logged at the track. (mostly road courses) I don't know what gauges I need to be looking at besides boost for slip. I boost a max of 17.9 psi with my code 3 (aluminum) My car seems a touch slow for the modifications (best of 12.72 at 108) I assume it's slipping a bit because sometimes I don't make 17.9 psi but more like 17.5 but I don't smell the belt burning or see signs of slippage. Either way, I'm up for the kit just to be sure.
Les
Old Feb 14, 2010 | 08:46 AM
32krazy!'s Avatar
Les
do you have a tune for the c3? without a tune and some mods to my airbox and a set of dr's i ran a 12.7 along with bmorgan. after the tune bmorgan has cut a full .5 off his time. i havent been able to run due to weather.
i dont think its slippage but normal times for the mods you have
so the kit will be here next week. rob has outfitted me with some belts and the 178 psk to install on my slk32 with a c3 pulley. once all the belts are tried and the best for the setup is run for a couple weeks this should become available to the c3 crowd!! better bearings, bigger pulleys and a belt wrap all in one!!
pics and impressions to follow.
Old Feb 14, 2010 | 07:01 PM
kolevski's Avatar
Krazy are you running a 178 crank pully aswell? did you end up buying the one from evo?
Old Feb 14, 2010 | 07:12 PM
32krazy!'s Avatar
no. just the c3 and oem crank pulley. i have been researching the evo but im still not convinced that a crank pulley is a good thing long term. however if i did go that route i do believe the evosport would be the pulley i would use. the dampening looks first rate. but im still pushing the c3 to its limits!
with bmorgan slamming a 12.22 and moparburst firmly in the 11's i think the c3 will do the job as well as a crank pulley. i just cant get any decent weather to try!
Old Feb 15, 2010 | 01:04 AM
kolevski's Avatar
I agree with you, I've heard someone melted there supercharger running the C3 with a crank pully.
I think Bob could have gone into the 11's but apparently the track wasn't prepped right and we all know how important that is in terms of acheving our best times.
How much do you think this belt wrap kit will cost?
I took my s/c idler pully and put it above the altenator it seems to be abit tighter that way (not sure if it is, but I think it is) and it seems to be putting down power really good.
But if this kit was at a good price may aswell have the peace of mind.
thanks for doing the research and doing this krazy it's great when people experiment new things.
Old Feb 15, 2010 | 06:42 PM
32krazy!'s Avatar
the kit should be priced the same as the others. ill be using the 178 kit and trying some different belts that rob is sending me to find the best fit.
while the belt wrap is an added plus my goal is to eliminate the oem cheap pulleys which keep failing and use the better larger pulleys from the kit. thats true peace of mind!!
im on my 3 rd idler pulley and 2nd tensioner pulley in just over a yr. not really experimenting just bugging the real mechanics to adapt what i need for my car!! they do it so ill go away!!!
smfrycruzr
Jul 17, 2023 05:33 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
