180 thermostat mod
Old Jul 30, 2013 | 08:48 PM
ImportLabSRT's Avatar
Default Re: 180 thermostat mod
Originally Posted by JesseJamessrt6
Thank you for posting good feedback, i appreciate it, but why is there such an interest and market for 180 tstat then?
Because most people who buy mods do not know why they are buying it. They just hear "cooler" and "must have" so they buy it.
Old Jul 31, 2013 | 04:34 PM
Billy22Bob's Avatar
....ouch.....;>)
Old Aug 1, 2013 | 03:10 PM
boostmonkey's Avatar
Cooler engine temperatures can have several advantages:
  • The intake charge picks up heat from the plenums, throttle body, (supercharger if equipped) and even heads. Keeping these parts cooler keeps the intake charge cooler and thus denser. Density=power.
  • A cooler intake charge mixture resists knock better, thus allowing the engine to run more compression/timing/boost. These are usually design factors though.
Cooler engine temps can also have disadvantages:
  • The combustion gasses lose heat and energy to the combustion chamber surfaces. Too cool, and you can rob the engine of some efficiency and power.
  • As was said, the fuel and timing maps are based upon sensor data. Run the engine too cool without tuning changes to match, and you might be out of the ideal range for performance or efficiency. Same with too hot.
  • That was great info from ImportLabSRT about the need to evaporate water out of the engine oil. Viscosity is important too. Factors such as oil weight, bearing clearances, oil pump & piston squirter design, are all temperature based.
Old Aug 2, 2013 | 12:51 AM
JesseJamessrt6's Avatar
Thanks,
Have those that have installed the 180 tstat noticed any benefits without sacrificing performance or consistency? Did it effect the overall temp after heat soak?
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
