Selectable Sprint Booster testing
Old Oct 3, 2010 | 04:48 PM
waldig's Avatar
Talking Selectable Sprint Booster testing
I installed my new sprint booster to see how it goes.
I did the throttle reset before testing the settings. The positions are light off, low I believe, Green light, Medium, and red for high. I was not able to see much of a difference and can not give any results at this point.
From a roll at 3500rpm in first, I was able to blow off the tires and chirp second easily. This was the same in all three settings and back and forth I had similar kick *** response.
When I got my first TB it was night and day difference but it was not switchable so you had to pull the pedal to swap it in and out. Thats a long process and the checking between in or out is hard to compare but it was significantly better.
I will have to test it on the autocross track next week to see if I can see a difference. What I have to find out is what is the difference in the settings ---- is the dark off or regular sprint booster??
I dont think there is any problems with the booster, I just have to evaluate it under better circumstances. My car has mucho torque at the bottom of the rev range and opening the pedal it will leap forward. More when I can determine something. BTW I drove it 200 + miles today without any issues.
Woody
Old Oct 3, 2010 | 05:02 PM
BLACKSRT-6's Avatar
Default Re: Selectable Sprint Booster testing
What class do you run at autocross and where is the event next Saturday? Thanks
Old Oct 3, 2010 | 06:29 PM
waldig's Avatar
Talking Re: Selectable Sprint Booster testing
The car is not classes in CDC and we are simply timed, a lot like the fun runs as there are no tech rules, just safety. Run is at Bowie stadium in PG county, will you be there.
Woody
Old Oct 3, 2010 | 06:34 PM
BLACKSRT-6's Avatar
Thinking that I would, if the weather is decent. Prince George VA near Petersburg?
Old Oct 3, 2010 | 07:46 PM
waldig's Avatar
THink about 2 oclock on the 495 beltway. Its above the center of the circle on the eastern side of 495.Woody
Old Oct 3, 2010 | 08:43 PM
dinasrt's Avatar
Woody, Dark or(no light) = stock setting(SB off). You want red for race, green for going to the grocery store. I hope you see improvement at your next autocross run. Bob
Old Oct 9, 2010 | 07:05 PM
taz2005's Avatar
Just put the new Selectable Sprint Booster in my SRT6. WOW!!!! Turned off the traction control, but it on RED and I think my PERMAGRIN WILL NEVER GO AWAY.
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
Reliableron
Oct 17, 2015 10:19 PM
Sep 28, 2015 07:40 PM
tritongreen
Sep 18, 2015 07:32 AM
