First oil change
Old Mar 5, 2011 | 12:29 AM
Teuton's Avatar
Default First oil change
About to do my first oil change, I have searched but havent found too much information on what oil is popular with this motor.
I have read it takes 8.5 Qts??? 0W-40??
Thanks for any help
Old Mar 5, 2011 | 02:01 AM
dinasrt's Avatar
Default Re: First oil change
This should help you out. https://www.crossfireforum.org/forum...-pictures.html It was another members "How To" I got directly from the Search feature. Most everyone uses 0-40 Mobile 1. Have Fun.
Old Mar 5, 2011 | 10:51 AM
Teuton's Avatar
ok thanks, so does it take 8 qts or 8.5??
Old Mar 5, 2011 | 11:11 AM
Beaner's Avatar
Start with putting in 8, check it, if it needs a little more... put a little more in!
I have put 8 Litres in my car which is a little more than 8qts and it brought the level up to the top of the full line.
Old Mar 5, 2011 | 12:05 PM
Hawk Monster's Avatar
Becareful. Do not overfill; a little less is OK.
Old Mar 5, 2011 | 12:43 PM
dinasrt's Avatar
Anybody know why most of the filter kits come w/ an extra O-Ring?
Old Mar 5, 2011 | 05:46 PM
Teuton's Avatar
I went ahead and put in 8 qts, do you think I should another half??
Old Mar 5, 2011 | 05:48 PM
Teuton's Avatar
Lol this actually really confused me, I looked over everything a couple of times to find where the other O ring goes.
Old Mar 5, 2011 | 06:23 PM
The extras are a prize to wear on your fingers after the change.
Old Mar 5, 2011 | 07:44 PM
+fireamx's Avatar
I think some other Mercedes engines that use the same oil filter, have one more O-Ring on their bayonets, than Crossfires have.
I never put more than 8 qts of oil in my car. Some people have had problems with the car reading it as being "over filled" when using 8.5 qts.
Besides, it's better for it to be a little under filled than it is to be over filled.
Old Mar 5, 2011 | 09:03 PM
Always put in 8 quarts and go for a drive.
Check the oil level a little while after you have stopped and see if you still need more.
Mine is always right on the full mark with only 8 quarts with every oil and oil filter change.
minimayhem
16
Aug 23, 2016 07:47 AM
csteve0355
Sep 23, 2015 05:57 PM
lazorouss
Sep 11, 2015 09:16 AM
MickeyNasty
Sep 6, 2015 08:29 PM
PNA
Sep 5, 2015 02:20 PM
