CPS issue again? Maybe
Old Apr 4, 2011 | 01:24 PM
srtswizz's Avatar
Default CPS issue again? Maybe
A few months ago before I put the crossfire away for winter I had the CPS replaced due to a small rough idle and a occasional stall. Everything was back to normal after it was replaced and the car ran great. I took the car out a few times when the weather was very nice out and when I drove the car aggressively immediately after slowing down to a stop the car would idle very rough and throw a check engine light. I would turn the car off and restart it and it would run like normal again but the code would stay. The only code the car threw was a cylinder misfire. I changed out the plugs and wires and took the car out for a spin to see if it would run into the problem. The 1st day post change it did not but then the next day the same old issue occurs. Should I change out the CPS again? Vacuum leak? Fuel filter? Any advice would be great.
I'm hoping to get this figured out before I throw the code 3 pulley on and then get tuned by Eurocharged in the next month or so.
Old Apr 4, 2011 | 02:28 PM
tunaglove's Avatar
Default Re: CPS issue again? Maybe
If you didn't change the CPS yourself, check around the throttle body for leaks, this would include the hoses for the PCV system. Then put a fuel pressure gauge on the fuel rail and check that. Should be about 56 psi running. Also re-torque your manifold bolts and check the 4 clamps at the back of the engine, these are known to leak air also.
Air leaks and/or low fuel pressure can cause a lean missfire.
Old Apr 4, 2011 | 02:58 PM
srtswizz's Avatar
Thanks for the good ideas, I did not install the cps myself as I did not have the correct tools at that time. I will check around for leaks and re torque the bolts before I move onto the fuel system. I also ordered a bosch CPS just for the hell of it to see if maybe the autozone one I bought went bad. Thanks for chiming in and the good ideas tunaglove.
Old Apr 4, 2011 | 04:31 PM
MikeR's Avatar
Did you get the codes read when you got the CEL?? If the CPS is the problem it should be showing a P0335 code.....
Old Apr 5, 2011 | 08:39 AM
srtswizz's Avatar
I did not get the codes read again, the times when I did get it checked it would say cylinder 3 misfire (cant remember the exact code).
Old Apr 5, 2011 | 09:05 AM
tunaglove's Avatar
Check these basics, then write down and clear the code. The code number would help troubleshoot.
Old May 16, 2011 | 10:25 PM
srtswizz's Avatar
I resolved the issue! It was the CPS, the CPS that was faulty was from autozone and when I compared it to the bosch one I replaced it with, the autozone one was slightly longer and due to that it most likely gave inaccurate readings.
Valk
Jun 22, 2025 09:15 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
skeet370
29
Sep 18, 2015 05:53 AM
