How many quarts of oil do I need?
Old Sep 9, 2011 | 01:35 PM
X-Fire_srt6's Avatar
Default How many quarts of oil do I need?
This Tuesday will be my first oil change on my SRT6 done by myself.
Should I stick with Mobile 1, because I am thinking about Royal Purple...
Thanks guys
Old Sep 9, 2011 | 02:07 PM
maxcichon's Avatar
Default Re: How many quarts of oil do I need?
8 works for me. Some here say 8.5. But I think they have leaks!
Old Sep 9, 2011 | 03:05 PM
BarbieGirl's Avatar
My husband taught me to run the old stuff through a coffee filter and then top it off until the dipstick reads full. I usually only have to add 1/2 a quart or so. Much greener for the environment.
Old Sep 9, 2011 | 05:07 PM
Thank you!!
Old Sep 9, 2011 | 05:23 PM
PNA's Avatar
PNA
Read the manual. It's 8.5. That's what came out of mine and what went back in. No leaks, no consumption and both the stick and electronic reader indicated it was spot on.
Old Sep 9, 2011 | 05:41 PM
That oil has been through a filter umpteen times, a coffee filter alone will not do much good.
Your best bet is to put all the oil through a coffee maker using a medium ground dark roasted Columbian bean.
It makes the oil darker and it smells a lot nicer. The main benefit being it perks the engine up.
Old Sep 9, 2011 | 06:45 PM
kurtisberry's Avatar
Really, I hope you are joking? You are not changing your oil, you are not doing any thing that the oil filter already does. Do you change the filter or did your Hubby tell you to just rinse it off?
I know Mobile 1 is amazing stuff, they claim it is good for 15 K, but how many miles can you push it before an engine replacement?
Old Sep 10, 2011 | 11:23 AM
8 quarts with a new filter and I'm right on "full" on the stick
I use only Mobil 1 0W40
Old Sep 10, 2011 | 06:08 PM
MI1XFIRE's Avatar
I follow the factory specifications:
8 Liters = 8.45 quarts
Never experienced any leaks
Old Sep 10, 2011 | 10:55 PM
Larry Hitze's Avatar
I'm with Valk, try as I might it will only take 8 qts on a change.
Old Jun 30, 2013 | 11:34 AM
LVXF's Avatar
WallyMart has Mobil 1 0w-40 in 5-quart jugs for $22.47
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
