Next Mod; Manifolds or Pulley?
Old Oct 24, 2011 | 05:42 PM
The Bobby's Avatar
Default Next Mod; Manifolds or Pulley?
I have the thermal dual cai, themal lower y, and xstream filters so my decision for the next mod is tune/pulley or tune/thermal manifolds? I am leaning towards the manifolds but I want to get the horde's opinion.
Thanks
Old Oct 24, 2011 | 06:57 PM
velociabstract's Avatar
Default Re: Next Mod; Manifolds or Pulley?
Wow, that's one I can't answer with confidence. I'd go pulley and tune though. I've got to ask, the thermal coated dual CAI .... tell me all about it.
Les
Jason_HBC's Avatar
Pulley and tune for performance. You have sunk a lot of money into the engine. Do not fail to overlook upgrading your brakes. Worst feeling is sailing into a turn and having no brakes.
Old Oct 24, 2011 | 07:01 PM
Thirteendog's Avatar
forget brakes, look at cooling if you add a pulley that supercharger is going to get mighty hot.
Old Oct 24, 2011 | 08:53 PM
Jason_HBC's Avatar
That supercharger can be cool, but if you can't stop you wont have a supercharger to be worried about
Old Oct 25, 2011 | 01:14 AM
Mimi05SRT6's Avatar
Eurocharged Pulley and Tune for the win....
Old Oct 25, 2011 | 12:14 PM
The Bobby's Avatar
Its very cool to be able to touch the metal not too long after the engine is off and not cook your hand, so I'm a believer in the thermal coating
Old Oct 25, 2011 | 12:15 PM
The Bobby's Avatar
I have the supercooler/iso kit installed too
Old Oct 25, 2011 | 01:19 PM
FUBU's Avatar
which one is that?
Old Oct 25, 2011 | 01:28 PM
ZAHANMA's Avatar
Originally Posted by FUBU
which one is that?
Here you go:
Needswings/Waldig Supercooler
and
Needswings Intercooler Fluid Isolation Kit
Old Oct 25, 2011 | 01:56 PM
FUBU's Avatar
Originally Posted by ZAHANMA
Thanks! I have seen the waldig one before but not the isolation kit. Might order it but I have never heard of it on the forum.. search engine here I come!
Old Oct 25, 2011 | 03:17 PM
ZAHANMA's Avatar
I've got the iso kit on my SRT and saw a pretty signifcant drop in running temps after install. The intercooler runs so hot that it affects the fluid that is cooling the engine, therefore, separate it and voila! cooler engine temps.
Fairly easy install. The hardest part for me was getting the air out of the system after install...I'm still not sure if I have it all out.
Old Oct 25, 2011 | 04:07 PM
loungn14's Avatar
sc pulley and tune!
More bang for your $
Old Oct 25, 2011 | 04:24 PM
Originally Posted by loungn14
sc pulley and tune!
The mani's create more volume for more boost. Without a pulley, you are still at stock... So, pulley and tune, or pulley, mani's, and a tune...better yet...it's only $$$$$$$....
Old Oct 25, 2011 | 08:18 PM
loungn14's Avatar
listen to this guy....he knows what he's yappin about!
Old Nov 1, 2011 | 01:52 AM
simmie777's Avatar
so does that mean the mani's limit boost or the pulley? or is it determined by both? so if you had a 185 pulley making 28psi it could potentially make 30psi with the upgraded manis. Learning slowly so be gentle
Cheers,
Michael
Old Nov 1, 2011 | 02:30 AM
kolevski's Avatar
Cheers,
Michael
The other way around Michael, the larger mani's produce less boost but flow more volume that results in the HP gains.
John
Old Nov 1, 2011 | 06:11 AM
simmie777's Avatar
Thanks John
Old Nov 2, 2011 | 07:20 PM
chuK_138's Avatar
Easy answer is pulley/tune. But if you have an extra $1500 lying around..................
Old Nov 2, 2011 | 07:28 PM
grip grip's Avatar
Pulley and tune is a no-brainer.
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
