need help w/alarm please
Old Jan 26, 2012 | 06:10 PM
fastfred's Avatar
Default need help w/alarm please
i have a 2005 str-6 and my alarm keeps sounding off with no rime or reason.. i mean like 2am setting in my closed garage it starts squealing sound not the horn and all the lights start flashing and in different places and different times ....does anyone have a idea why??? i have checked everything i could think of... please its been doing it for 2 days now 7 or 8 times in a 24 hours......
Old Jan 26, 2012 | 06:53 PM
Default Re: need help w/alarm please
Try this thread.
https://www.crossfireforum.org/forum/crossfire-coupe/16586-car-alarm-keeps-going-off-dead-battery.html
Old Jan 26, 2012 | 07:28 PM
BLACKSRT-6's Avatar
Still have the 7 year old stock white battery?
Old Jan 26, 2012 | 07:39 PM
fastfred's Avatar
thank you for that info but i had already read that one and a few others like it when i did a search and went thru the check list that was posted, and all my stuff seems good ,no water leaks,the battery int he car is good the battery's in key fabs good.......i have gone thru all the stuff that i could find when i did the search ....the only thing is maybe the unit itself but will that also make the lights go on and off ?
Old Jan 26, 2012 | 08:03 PM
Yes, the siren itself can go wrong and the new siren ($150 or so) will beep when you lock and unlock the car.
Old Jan 26, 2012 | 08:52 PM
fastfred's Avatar
thank you for the input ...i do understand the siren can go bad but will a bad siren cause the lights and door locks to activate?
Old Jan 26, 2012 | 10:07 PM
Reliableron's Avatar
I can't remember about the locks but the lights flash when the alarm goes off. If it is in the garage I would suggest leaving it unlocked to stop the siren. Note: if it is locked and you unlock it with the FOB it will lock again in a few minutes if you don't open the door, so make sure to open the door to keep it unlocked. I left mine unlocked for a few days and had no problems with the siren while I waited for the part to come in and time to install it.
Old Jan 27, 2012 | 10:51 AM
JimmyJames's Avatar
If the battery is under 4 years old, then the Skreem would be what I looked at next---Many have gone bad---Good luck, Jimmy.
Old Jan 27, 2012 | 11:23 AM
The air pump/security module in the trunk under the foam on the passenger side has caused problems when it has got wet due to a trunk leak. This pump is an integral part of the security system, as it arms the alarm system.
Pull up the trunk carpet and peer down the back of the foam and look for water in the well. Look for signs of water in the trunk while you are at it.
Old Jan 27, 2012 | 12:43 PM
JimmyJames's Avatar
+1---Also needs a good look!!!
Old Jan 27, 2012 | 02:56 PM
fastfred's Avatar
yea found a lot of water in the rear pocket on the passengers side .i felt the carpet and it was dry ...in the pocket back there i keep my polishing rags and did not notice till i pulled them out that they are soaked ... OK water in rear pocket ,now what do i do?????
Old Jan 27, 2012 | 04:34 PM
fastfred's Avatar
THANKS GUYS YOU WHERE RIGHT ON THIS ONE.....well i did some searching on here and found a lot of posts on this water in the rear area ...so i took apart the whole trunk area and under the foam thing i found about 6'' of water so i opened up the drain hole and let the water out... the foam thats around the module is soaked so i took it out and its drying now i also took all the pins loose and found water in all of them but no rust and no black shorting looking wire at all... so i have it all a part now and drying am i missing anything at this point?..... I'm hoping after it all drys I'll put it back together and hoping it works????
Old Jan 27, 2012 | 05:15 PM
Find the leak.
1, It's coming from the rubber boots that cover the wires and hoses going into the hatch, They are at the top of the hatch door.
2, It's coming in around the screws that hold the wing on.
3, it's coming under the panel that the wing bolts to.
4, It's coming in the gas cap area.
5, ?
Old Jan 27, 2012 | 05:50 PM
fastfred's Avatar
thank you onehundred80 you are full of info again that you for your help.... what do you think about drying everything out and it working, have you heard of this being a possible??? i don't see any shorting black wires or rusting.....
Old Jan 27, 2012 | 06:24 PM
Dry it and try it, these are not cheap items, $400 or so new at least.
Old Jan 27, 2012 | 08:54 PM
fastfred's Avatar
well the alarm stopped going off all the time but now the parking lights are on all the time
Old Jan 27, 2012 | 11:23 PM
Not sure but when I pulled fuse # 9 to stop the alarm siren the parking lights flashed on and off. I ended up putting it back in to turn them off - might be worth checking to see if it is blown.
Old Jan 28, 2012 | 01:35 PM
fastfred's Avatar
thank you for your input.....i did check the fuse when i started all this but it may have blow with me taking all this apart and putting it back again so I'll go check it again....my parking lights are stuck on ....thank you....
Old Jan 28, 2012 | 02:24 PM
fastfred's Avatar
now bam just like that nothing works right the locks keep locking and unlocking by there self, the parking lights are on all the time , the key fob does not work, the alarm is again going off by its self,..... and the rear hatch is locked and i cant get in the rear to the little black box to work on it is there a way to open the rear hatch manually???? thank you for any help.....
Old Jan 28, 2012 | 03:18 PM
fastfred's Avatar
well it looks like you cant dry them out and have them work so I'll have to pop for a new module....anyone know where the bet place to get one?
