The 6 is being a PITA :(
Old May 16, 2012 | 11:42 AM
The Beep's Avatar
Default The 6 is being a PITA :(
So after all that work replacing the IC pump and washer reservior, the SC still isn't working.
I'm just going to bring the thing down to Jerry (EC) and pay him to figure it out.
I'll ask him to install the oil catch can as that appears to be a PITA as well.
I'm sick as a dog and just paid a $250 speeding ticket so if I sound a little grumpy, there's good cause.
Thank you for allowing me to vent.
Old May 16, 2012 | 11:57 AM
srtswizz's Avatar
Default Re: The 6 is being a PITA :(
Check the fuse for the intercooler pump
Old May 16, 2012 | 12:59 PM
ZAHANMA's Avatar
This is very similar to the issue I had when I first purchased my SRT. You should check the ambient temp sensor. Mine was faulty. It showed correctly in the cabin, but was sending the ECU that it was -36 outside, which made the computer add fuel to keep operating temp appropriate...well when it is 80+ outside, that leads to the S/C overhearting.
It is like a $10 part or something like that and it simple to replace. I don't have the part number off hand here at work, but I'm sure you can find it...or just call the dealer and see what they want to charge you get you a new one.
Old May 16, 2012 | 01:03 PM
tunaglove's Avatar
How did you find the -36*F ? OBDII?
I thought the IAT sensor in the Y-pipe controlled fuel/advance.
Old May 16, 2012 | 02:45 PM
The Beep's Avatar
I just got back from EC and Jerry verified the SC was turning on by unplugging the clutch (clever).
He gave the car a tune and I like the throttle response now but after driving home, it just doesn't have the hair-raising power that it used to have.
I'm wondering if something could be blocking the air intake or maybe the SC clutch is slipping or something???
The car has 11K miles so it sat in storage a lot.
Old May 16, 2012 | 02:54 PM
dtinker's Avatar
What kind of RWHP and Torque are you getting? Is the A/F correct? If all those things are good it is not the air intake.
Old May 16, 2012 | 03:07 PM
magredvet's Avatar
Brian , did you burp/bleed the supercharger intercooler circuit by pinching the hose, like we discussed, after installing the pump ?
You may have air in the system which needs to be purged ..........
https://www.crossfireforum.org/forum...placement.html
Old May 16, 2012 | 03:25 PM
ZAHANMA's Avatar
Unplug your Ambient temp sensor from the driver's side lower louvre. Then go check the cabin, it will read one of two things...either -36 or 136 ( or something like that). That is how I found it. The IAT sensor does control fuel/advance, but one parameter is also knowing what the ambient temperature is.
This is also about keeping the whole engine from being well below operating temperature, which is what would happen if the outside temp really was -36.
Old May 16, 2012 | 03:42 PM
The Beep's Avatar
Yah, I've done that a few times but never saw any air burp out. When I replaced the pump, no coolant came out which seemed weird.
I'm not sure I should drive this to Dallas until it gets figured out.
Old May 16, 2012 | 03:48 PM
magredvet's Avatar
It hasn't got a needswings coolant isolator setup has it ? ...............in which case you'd need to let the coolant back into the IC circuit before topping up, and closing the isolation valves again
Old May 16, 2012 | 06:02 PM
The Beep's Avatar
No it's stock...and what's an isolation valve?
Old May 16, 2012 | 06:04 PM
The Beep's Avatar
I'll check it out. What/where's a louvre?
Old May 16, 2012 | 06:07 PM
bluecoupe's Avatar
NeedsWings Intercooler Fluid Isolation Kit
Old May 16, 2012 | 06:17 PM
The Louvre is in Paris.
I think he means lower front driver side grille.
Old May 16, 2012 | 10:02 PM
The Beep's Avatar
I think it's ironed out.
1 of the problems was the w/s switch was in the w position. Reading up on that it appears the car will start off in 2nd gear and won't downshift as easily.
Not the best scenerio when trying to go fast.
Btw, hat's off to Jerry at Eurocharged. That tune was worth every penny.
Old May 17, 2012 | 05:51 AM
magredvet's Avatar
Btw, hat's off to Jerry at Eurocharged. That tune was worth every penny.[/QUOTE]
Told you.................now it needs a pulley and an intake ...........
Old May 17, 2012 | 08:32 AM
ZAHANMA's Avatar
Meh, you say potato; I say octopus. Same difference.
Yes, the lower driver's side grill.
Old May 17, 2012 | 08:14 PM
you aren't the first one to make that mistake.....I have seen others on here bump the switch...but when you put her back in summer mode....it feels even faster than before...lol
maxcichon
Apr 21, 2021 08:29 AM
drummertom
May 17, 2019 11:26 AM
Musclefan21
Sep 5, 2012 07:11 PM
GraphiteGhost
Apr 1, 2012 05:27 PM
maxcichon
Aug 30, 2008 10:59 AM
