Noisy Roller/Rocker/Tappet.....
Old May 28, 2012 | 06:01 PM
Billy22Bob's Avatar
Default Noisy Roller/Rocker/Tappet.....
Changed the oil on my new SLK32 (80k miles) - oil was dirty and thin, filter was clogged, my oil extractor syphon pump stopped a couple of times duirng the change due to what I suspect is sludge in the sump.
Anyways - it has new Mobil 0W40 in it now and a new filter. Will change out again in 600miles along with a sump drop and cleanout/inspect bottom end etc. Change oil level switch.
After I changed the oil - it seems to have developed a single tick (2 per second at idle) from one of the RHS rockers/valves. It's only intermittent, I'm thinking more noticable when cold.
Recommendations?
Previously with motors (4cyl), I've lifted the rocker cover and analysed the problem and adjusted - however with this V6 I'd imagine this would be a very messy business - the banks being on angles I mean.
Also I suspect the gap may be adjusted through shims (?), as opposed to screwed and a lock nut.
Thoughts/links?
Any other business I should be attending to whilst I'm in there?
New gaskets if I do it - or just be careful and reuse the old ones?
Last edited by Billy22Bob; May 28, 2012 at 07:13 PM. Reason: change oil grade to 0W40W
Old May 28, 2012 | 06:37 PM
bluecoupe's Avatar
Default Re: Noisy Roller/Rocker/Tappet.....
I can't find where Mobil1 10W40 is a recommended oil, especially for the AMG engine. Why not use Mobil1 0W40?
Old May 28, 2012 | 07:14 PM
Billy22Bob's Avatar
apologies - changed to 0W40W
Old May 28, 2012 | 07:29 PM
Recommendations?
Thoughts/links?
They are self adjusting. Dirty oil can plug the adjusters.
See if they quieten up with the clean oil.
Old May 28, 2012 | 11:14 PM
The Beep's Avatar
I'm a big fan of Seafoam. It's been going in all my machines for 30 years and have never had a problem.
boobles37
Jul 2, 2023 10:05 AM
grip grip
Oct 1, 2013 09:56 AM
hbv2020
Jul 26, 2013 03:06 PM
CB20
U.K.
Mar 15, 2012 01:38 PM
jimhagner
Dec 11, 2009 05:49 PM
