Disassembling the SRT stock intake
Old Jul 28, 2012 | 03:03 PM
Default Disassembling the SRT stock intake
Anyone have any tips on taking this thing apart to put into a box for storage?
I assume that the squarish box unsnaps and I would hate to break any tabs on it.
Old Jul 28, 2012 | 04:07 PM
Beaner's Avatar
Default Re: Disassembling the SRT stock intake
Here you go! Works great for making thing smaller with out breaking any tabs! Fit in ANY size box you want!
Old Jul 28, 2012 | 04:42 PM
32krazy!'s Avatar
the y pipe has a tab on top and on the bottm. most folks tend to break either of the tabs. gently unclip the top then tilt the ypipe to unclip the bottom. wrap carefully and box
Old Jul 28, 2012 | 04:53 PM
Great minds think alike.
I am doing that now, the battery was flat when I posted. Twenty minutes later I was all set. I am getting excellent results with 32 T.P.I. blades. I used a sharp hooked knife on the rubber parts. I have an old blender and with luck it will all fit in a coffee can. I'll sell the filters, no sense in being wasteful.
I'll start a new thread on the How To, with the pictures I've taken. I'll be using a 18V Milwaukee Sawzall though, same diff.
Old Jul 28, 2012 | 05:05 PM
JHM2K's Avatar
^^^ This.
Those tabs can be a PITA... Once those are out, the rest of the box is a cinch to get off.
Old Jul 28, 2012 | 05:37 PM
Originally Posted by JHM2K
^^^ This.
It's off no problem, that's the easy part. I just want to break it down into pieces for packing away. Those tabs look awfully vulnerable, especially the bottom one.
I think it should break down into 7 pieces with some luck
. Those clamps on the rubber look permanent, I guess they will be ruined.
Storing it in one piece is asking for trouble, it's such an awkward SOB to handle.
Old Jul 28, 2012 | 05:54 PM
JHM2K's Avatar
At one point I had both the SL-55 intakes and the OEM SRT intakes. Either is as awkward as the other.
The metal clamps joining the Y-pipe to the boxes are a SOB to get off... Unless you have the tool for it, of course. I didn't.
As for storage, I simply put them in a really wide/flat box, and bubble-wrapped the sharp edges extra thick. No issues with damage.
Old Jul 28, 2012 | 07:01 PM
bluecoupe's Avatar
just hang it on your garage wall
Old Jul 28, 2012 | 07:02 PM
one piece wall art Dave....I sold one to BikeCop when he put his back to stock. I have another I would sell if anyone wants to go back to stock. My cars will never be stock again...
Old Aug 17, 2012 | 05:23 AM
BadSRT2005's Avatar
I think it should break down into 7 pieces with some luck . Those clamps on the rubber look permanent, I guess they will be ruined.
To remove the permanent looking clamps you can get a tool/pliers off Ebay to remove AND reinstall them! If you search "mercedes clic" around 4 results will pop up and they're all the same!
Hope this helps!
Old Aug 17, 2012 | 09:34 AM
Hope this helps!
Thanks for the help, I want to pack it away safely.
Thanks again for your reply.
waldig
Jul 31, 2017 09:46 AM
axnguyen
Jul 21, 2015 11:41 AM
Beeker
Jul 20, 2015 03:46 PM
waldig
Jul 20, 2015 08:10 AM
bradleykologek
Jul 6, 2015 02:49 PM
