62mm SRT6 Pulley Available Now
Old Oct 28, 2012 | 01:32 PM
  #181 (permalink)
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: 62mm SRT6 Pulley Available Now
Originally Posted by cjw
Went to install mine today. Which way does the spacer ring face? Machined side in or out? Both look righ id just like to be sure
This is what you are looking for : https://www.crossfireforum.org/forum...tml#post679120
Old Oct 28, 2012 | 01:51 PM
  #182 (permalink)
rcompart's Avatar
The recessed pocket is for the sheave washer.
The ring goes on after the pulley. It's used to make up the difference in depth from using a smaller diameter bearing.
This face goes up against the bearing after the pulley is mounted on the supercharger.
This recessed groove is where the sheave washer sits in.
What is should look like before you put the bolt and sheave washer on.
Old Oct 28, 2012 | 09:44 PM
  #183 (permalink)
Leptronjohn's Avatar
Robert came over tonight and showed me how to install the pulley, dummy me. We did have to take it for a short run, yahoo... ok, now I will retune..
Rudy, the pulley looks good and is a great piece of machine work. nice tight fit, no clearance problems.
runs true.. ok, I like it.. thanks
john
Old Oct 28, 2012 | 10:31 PM
  #184 (permalink)
cjw's Avatar
cjw
Took mine out for a drive.. definetly more torque, gave the car a deeper growl and had more air flow. I do recommed the Psk for anyone with this pulley, even with a brand new belt i heard some belt slip when letting off the throttle. I will have the psk installed this week and hit the track with some 100 octane fuel this saturday.
One question I do have, im running a needwings single cai do you experts think thats sucking enough air or should i upgrade to a dual?
Old Oct 28, 2012 | 11:24 PM
  #185 (permalink)
CJW,
it really is a big difference. On the duel cold air, yes it will be noticeable.
I would not push it without a tune. I am sure we would hurt the thing.
jo
Old Oct 28, 2012 | 11:48 PM
  #186 (permalink)
cjw's Avatar
cjw
Originally Posted by Leptronjohn
CJW,
jo
I have it tuned for thr 65mm now and will be re-tuning next week, I was hoping the single needwings was enough cause the engine brace I have on the car doesnt have enough room on the driver side for the second pipe. Guess I will have to see what can be done.
Old Oct 29, 2012 | 03:37 AM
  #187 (permalink)
FUBU's Avatar
I thought an IC upgrade, fuelpump upgrade and tune was à must when getting the 62s?
Old Oct 29, 2012 | 02:26 PM
  #188 (permalink)
latemodel21's Avatar
Got my Pulley, Looks Really Nice !
Thanks so much for your involvement in getting this top quality part done for us, Rudy !
It was definitely worth the wait and I am confident that it will be the best solution for my needs at any price.
Chris
Old Oct 29, 2012 | 10:06 PM
  #189 (permalink)
Fubu,
We just let you think that so we could get ahead of you. :-)
John
Old Oct 29, 2012 | 11:02 PM
  #190 (permalink)
rcompart's Avatar
To everyone that was part of the group buy, thank you for the kind compliments. I appreciate everyone's patience with the delayed delivery and apologize to those that we were unable to to deliver in a timely manner. I also eagerly await track and dyno results from the Crossfire crowd.
Take care
Old Oct 30, 2012 | 03:49 AM
  #191 (permalink)
FUBU's Avatar
Fubu,
John
That is exactly what I thought so I bought the 61 mm yesterday.
Old Oct 30, 2012 | 07:42 PM
  #192 (permalink)
cmz's Avatar
cmz
got my 62mm pulley installed today.this thing is really nice,well worth the wait.also installed the PSK,didnt get any instructions with it so just went to needswings web sight and looked at their good photos. whole procedure was easy,although belt seemed a little loose. went for a test drive and immediatly threw the belt. after some experimentations i replaced the tensioner pulley with a 100mm pulley(NAPA #38002)end or problem.thanks a bunch for involvement Rudy.
Old Oct 30, 2012 | 07:53 PM
  #193 (permalink)
rcompart's Avatar
Glad to hear you're enjoying the pulley. Can you do me a favor and check which belt you're using.
Take care
Old Oct 30, 2012 | 09:52 PM
  #194 (permalink)
cmz's Avatar
cmz
i used the one that came with the PSK. What are your thoughts.
Old Oct 30, 2012 | 09:58 PM
  #195 (permalink)
rcompart's Avatar
Did you order the PSK for the smaller SC pulley? I'd like to make sure this is just an isolated case. I told Rob that the same one used for the C3 would work with this one but I have more belts and pulleys that I've had on and off the car than I can shake a stick at and and I may have wrote down the wrong combo between the belt and combo of pulleys and want to nail down for sure what combo needs to go with these.
Take care
Old Oct 30, 2012 | 10:02 PM
  #196 (permalink)
K081153.............
Old Oct 30, 2012 | 10:14 PM
  #197 (permalink)
rcompart's Avatar
Well I have a K081145 which is the factory size belt, a K081153 which is the one Rob sent me with the PSK and I have a few 8-rib grooved pulleys of various sizes, three 100mm smooth pulleys and two 90mm smooth pulleys so gonna have to do some homework before I say for sure but if CMZ is using two 100mm smooth pulleys and it has the tensioner in the middle where it is applying the right amount of belt tension, that will be the right path to take. Sorry for any confusion with this.
Take care
Old Oct 30, 2012 | 10:20 PM
  #198 (permalink)
cmz's Avatar
cmz
yes thats what i am using( two 100mm pulleys). appears tensioner is close to the middle.
Old Oct 30, 2012 | 10:31 PM
  #199 (permalink)
cmz's Avatar
cmz
sorry yes i did get the PSK for the smaller sc pulley
Old Oct 30, 2012 | 11:33 PM
  #200 (permalink)
JesseJamessrt6's Avatar
cmz, would you mind posting a few pics of your solution with the 100mm tensioner pulley from Napa?
I just checked my psk from Rob for the smaller SC pulley and the belt # is also a K081153 and included 3 pulleys, a 90mm smooth, a 100mm smooth, and a 90mm 8-rib grooved.
