Supercharger still only kicks in 75% of time :/
Old Nov 12, 2012 | 03:07 PM
Dal's Avatar
Dal
Default Re: Supercharger still only kicks in 75% of time :/
that's all you need it's simply plug and play and takes no more than 30 minutes to swap it over (just DON'T do it with a HOT engine).
There a step by step guide on this forum of how to install it. Just use the search facility at the top.
Old Nov 12, 2012 | 09:24 PM
syfi's Avatar
Yup, It's just plug and play. Here's a pdf showing the removal of the old pump and replacement with a Johnson pump. Just reverse the uninstall and you're good to go!
https://www.crossfireforum.org/forum...on-ic-pump.pdf
I replaced the Spring hose clamps with new SS Worm clamps as shown in picture #8 just for a little more peace of mind.
Old Nov 13, 2012 | 08:54 AM
JimmyJames's Avatar
You may want to show this link to the service writer and get it done for free---There should not be ANOTHER deductible since the problem was never solved---SAME problem = SAME deductible.
ALL the service departments would save time and the warranty companies would save money if they would READ this forum---THAT SIMPLE......
Old Nov 13, 2012 | 04:08 PM
Originally Posted by jimmyjames
you may want to show this link to the service writer and get it done for free---there should not be another deductible since the problem was never solved---same problem = same deductible.
All the service departments would save time and the warranty companies would save money if they would read this forum---that simple......
+2.............
Old Nov 16, 2012 | 01:28 AM
Zoodust's Avatar
Just finished the install earlier today... IT WORKED !!!
Thanks everyone
Old Nov 16, 2012 | 04:41 PM
Fantastic!!!!!!!.......
gblack32
Sep 7, 2016 08:27 PM
tom2112
Oct 26, 2015 08:18 PM
FiftyThree033
Jul 26, 2015 09:24 PM
UNDER PSI
Jul 18, 2015 02:12 PM
mike28117
Jul 10, 2015 10:51 AM
