Inconel Headers
They look absolutely awesome as usual for Robs stuff. However, I would bet that the gains on the dyno will be minimul. The only way to gain much HP here is with equal length headers which will be extremely difficult if not impossible to construct with the room that is available. It might be possible but probably would require lifting the engine for installation.
Thanks and will do. It's crappy, cold and snowy up here right now and I've got a healthy amount of work to do to the car but this spring when the tracks open back up, should be for a real good time messing with people both there and on the way to and from! LOL
Newbie to headers here so please excuse the observational question? Should the last bank (rearward) be turned towards the front any? Seems to me that would cause a small amount of reversing flow towards the front two? Anyway, are you going to dyno before and after just this (headers) mod, to see if these actually provide any gains?
My car is AWD so getting it on a dyno is either expensive or a PITA to line up a time that works for all parties involved but I'm guessing Rob will have some before and after numbers on his C32 shortly
Measured up the stock exhaust and the surrounding sheetmetal on the underbody and put something together in solidworks. I designed this with 2.5" up front and 3" after things merge together. I made everything as straight as I could but the part around the center diff and front driveshaft proved to be rather tough so I used the same routing as stock. This model was more or less to see where I could straighten things up and what bends could be omitted and which ones needed to stay and to get a good idea what bends I'd need to get. This file right now couldn't be used to build one and bolt it on the car but it wouldn't be too tough to correct if it was be something that was to be used for manufacturing and you noted your changes as you did things.
I really should try though as it just sits here. How hard can it be?It really kicked AutoCad out the door on it's ****. Just as well I retired as I may have been kicked out the door with the ACad.
Until I can see Robs C32 downpipes to determine if it will be possible to make them work around the 4matic componenets and what would all need to all be changed, nothing is going to be made or bought.
Hey Rudy I am a very patient guy........I never have a problem with the time it takes to see these things through......unlike some on here who get impatient with the development of new products with nasty comments or little understanding for the development process. It all is a work in progress and takes time.
I was the last guy in the header group to get my money back and it was sent back not because I requested it. I would still be "in" on that deal if it were not for some. It is very few and far between that anyone is willing to develop new products for our orphaned cars so I am very grateful and patient when things come along.
That's nice I wish I could do it, I have my old bosses fully licensed SolidWorks 2012 setup on a computer here to learn, but after using AutoCad for so long I just cannot wrap this old brain around it. No patience these days.
I just wish we could get our Generators in a 3D model!
lets put your money were your mouth is. i have a shop that will build you a set of headers in less than 2 months. send your car and a large amount of cash and i will get it done. until then sit back shut up and let others do the fab work for you
you sir have no idea what your talking about. your were the last on the group buy? i was the first. in fact i arranged for the headers to be sent for mock up fab. after 7 months of nothing you expect me to just sit back and wait while they proclaim they have NO PROJECTS to do so they are going to build a s/c for the e55?
I am not in the habit of posting on this forum just to start some BS so I can make others feel justified by their actions. If the shoe fits wear it other wise don't comment on posts if you are not in a position to know what I am speaking of. You sir have no respect for others or you would not insert yourself in comments and assume you know anything about what I am talking about. If you had a problem in the past that is your problem and doesn't involve me. You need to backoff and find some manners. Nobody said anything to you Steve or about you so post when you have something constructive to say.
thank you for posting up some pictures Rudy, yes still playing with the r170/193 headers
btw, did anyone know that a 193 prefixed part number means crossfire instead of slk and not interchangeable, such as the rear trunk shocks
