OEM battery finally died
Old Mar 3, 2013 | 06:19 PM
Hog Red's Avatar
Default OEM battery finally died
Cant complain though, 8 years and 70K miles. Hope the new one lasts that long.
Old Mar 4, 2013 | 12:17 PM
Buggin's Avatar
Default Re: OEM battery finally died
My OEM battery was still going strong at 9 yrs and 70k. I only changed it because I was shipping the car overseas and wanted to make sure I had a good battery when I picked it up... I stuck with the Interstate long life battery. Only difference is it's black vs the OEM white.
Old Mar 4, 2013 | 07:16 PM
Thomas B. Whyle's Avatar
My battery lasted 8+years. I bought a Sears DieHard at the local Kmart - $99.00 with core exchange. It is identical to the original down to the swing up carry handles and vapor collector on the end. 650CCA, 3year free replacement. TBW
Old Mar 6, 2013 | 05:29 AM
musicnsurf's Avatar
I replaced the Varta in the black one late last year. Those were great batteries. I'd probably still be going if I ran trickle charge on it.
Old Mar 6, 2013 | 06:22 AM
Buggin's Avatar
Fwiw:
The Interstate I bought is MTP-48/H6
770 CCA / 965 CA
85 mo warrantee
I always try to stay the same CCA or higher if possible.
Old Mar 6, 2013 | 09:58 AM
beasticles's Avatar
I have a Wal-Mart battery in mine that replaced the OEM one and it has worked great for the past two years.
Old Mar 6, 2013 | 08:16 PM
Hog Red's Avatar
i wanted to go with an optima but nothing showed up in the computer so i'm assuming it would not fit.
Old Mar 7, 2013 | 01:47 AM
syfi's Avatar
I would highly recommend the AutoCraft Gold Battery, Group Size 48, 730 CCA from Advance Auto Parts.
This battery is made by Johnson Controls, who also make the OEM White Varta.
Buy AutoCraft Gold Battery, Group Size 48, 730 CCA 48H6 at Advance Auto Parts
These are Engineered with PowerFrame positive grid technology.
Discover the PowerFrame® grid technology :: PowerFrame® TRUE STRENGTH
AdvanceAuto also has the AutoCraft Gold AGM made by Johnson Control.
Notice that the group size for AGM is called H6, which is same as Group Size 48.
http://shop.advanceautoparts.com/web...9-p#fragment-1
http://www.johnsoncontrols.com/conte...echnology.html
UPDATE on 11/9/2014: Use code M42 for 15% off purchase.
Old Mar 7, 2013 | 06:43 PM
Toolman's Avatar
I also recommend the AutoCraft Gold Battery from Advance Auto Parts. We replaced the battery on my son's Crossfire last month and it fit perfectly.
Old Jun 12, 2013 | 09:53 AM
ijaved's Avatar
Yea someone recommended that too but does not show a match. I will go to wallmart and see if it will work. Its probably the dimension which is the issue that's why.
Old Jun 12, 2013 | 11:08 AM
user 8202's Avatar
Banned
+1
Replaced mine four years ago. White
Old Jun 12, 2013 | 12:50 PM
Squirrel Crusher's Avatar
I've got 81,000 on the factory 2005 battery. All is well..Squirrel Crusher
rfourt
Aug 12, 2020 07:27 PM
spoiler
Sep 2, 2015 08:56 PM
Helot
Aug 15, 2015 04:19 PM
da pink
Aug 12, 2015 05:20 PM
Valk
Jul 20, 2015 08:17 AM
