Help please
Old Apr 13, 2013 | 11:01 AM
scomer88's Avatar
Default Help please
Hello All,
So this morning i get in my srt and try to start it. wont turn over, try again and it turns over. But when i went to get on the highway there was no power, it looses all power after 3k rpm. and idles a little rough. Now it takes two tries at least to start. Any ideas? CPS? thanks.
Old Apr 13, 2013 | 11:22 AM
Spudracer's Avatar
Default Re: Help please
Power and idle sounds like CPS. Not cranking sounds like an electrical problem. Battery OK? Start at the cheapest element and work your way through the problem. Does not sound like a cooling problem if the power problem is occurring at startup.
Old Apr 13, 2013 | 11:24 AM
scomer88's Avatar
So should i start with the CPS? is this one a good one to get?
Crankshaft Position Sensor | 2005 Chrysler Crossfire 6 Cylinders N 3.2L SFI SOHC SC | AutoZone.com
Old Apr 13, 2013 | 01:05 PM
Buggin's Avatar
That link takes me to vehicle selection page. Just make sure you get a Bosch unit. I've heard of a few with bad ones from Auto Zone. I believe Advance Auto has the Bosch ones if there is one in your area.
Old Apr 13, 2013 | 01:16 PM
scomer88's Avatar
Will do, ill see if i can find anywhere today that has one..if not ill order one..Thanks.
Old Apr 13, 2013 | 01:27 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Whoa.....wont be CPS if it doesnt even crank over !! Check the battery, battery posts and grounds for good tight uncorroded connections before I'd spend money anywhere.
Old Apr 13, 2013 | 02:15 PM
scomer88's Avatar
Battery is about 3 months old. It cranks over everytime on the 2nd try.
Old Apr 13, 2013 | 03:50 PM
Originally Posted by scomer88
Hello All,
So does this not mean that the engine does not turn over, or does it mean that the engine does not start ?
Old Apr 13, 2013 | 05:22 PM
Mrmiata's Avatar
Mine from Adv. Auto wasn't Bosch.. don't recall "brand name" off hand.. but its worked great for a year now. And has a lifetime warranty.
Old Apr 14, 2013 | 02:55 PM
scomer88's Avatar
So i switched out the CPS and it seems not to have changed anything. I did see a hose in the back that was not connected to anything. Ill try to upload a picture of it. Would that cause me any problems?
File Type: png
Old Apr 14, 2013 | 02:59 PM
scomer88's Avatar
Can i bring the battery to the local Autozone or auto store and have it checked? Do they do that?
Old Apr 14, 2013 | 03:15 PM
scomer88's Avatar
It starts the second attempt. It will just crank for a while the first try, then when i try it again it will start.
Old Apr 14, 2013 | 06:25 PM
Infinity's Avatar
that is the vacuum line for the ac recirculation door
Old Apr 15, 2013 | 12:26 PM
scomer88's Avatar
Should that be connected anywhere? or just open like that?
Old Apr 15, 2013 | 04:23 PM
scomer88's Avatar
Could the loss of power be the Intercooler pump?
Old Apr 15, 2013 | 10:12 PM
God_Likes_Tebow's Avatar
BOSCH CPS order on Amazon and overnight it. Trust me dont get a off brand one its all bad!
Old Apr 15, 2013 | 11:41 PM
Buggin's Avatar
Ok, before you do anything else. Drive it over to Autozone (or other auto parts place) and ask them to read your codes.
Also, doubting you have an intercooler pump problem. You would still have times with lots of power until the air intake temp rises too much.
Old Apr 16, 2013 | 09:31 AM
Infinity's Avatar
That hose connects below the throttle body and runs into a loomed harness, from there it moves up to the passenger side of the car into the box next to the battery. From there it exits and runs under the battery and into the grommet in the firewall, then its off to the door controller under and behind the glovebox.
If the recirculation door button does not work on the car check under the battery as it is common that some for the battery acid to eat it away or for the plastic to dry rot under there.
Old Apr 16, 2013 | 10:12 AM
scomer88's Avatar
I have a bosch CPS from amazon being delivered today. Ill change that out and see if it changes, if not ill go check codes. (im not getting a CEL) will any codes still appear?
Old Apr 17, 2013 | 06:04 PM
scomer88's Avatar
Ok so i put in a Bosh CPS that i got from amazon. No change. Didnt start the first time..cranked for a while but didnt start. Second try it started and idled even worse than before and sounded bad. When i press the gas it hesitates and sounds like its choking or something. Could i have done the CPS wrong? It seemed easy enough. just pushed it in tightened the bolt and plugged it back in.
