Starter Ignition Issue?? Need Some Help...
Old May 19, 2013 | 06:59 AM
God_Likes_Tebow's Avatar
Default Starter Ignition Issue?? Need Some Help...
Has anyone had to replace their starter? I was searching through some of the older threads for some answers.
My car clicks over one time. Battery is less then a year old. Still have power in the car.
Could it be the solenoid or actual starter? Is the starter like the CPS issue where u can basically stick to one brand or the car wont work properly?
Thanks.
Old May 19, 2013 | 11:18 AM
JEFASOLD's Avatar
Default Re: Starter Ignition Issue?? Need Some Help......
Before you go any farther, make sure it is not the battery. It can have enough to power the lights, etc, they don't require much, but not enough amps to crank the car. Take it to AutoZone or equivalent and check it. then start checking the connections. Do the cheap stuff first.
Old May 19, 2013 | 12:21 PM
Mrmiata's Avatar
When my battery went.. I got 1 "click" whenever I hit the key. Several attempts to start and only 1 click per attempt.
Being an automatic, I figure it was the "auto start" relay engaging.
Old May 19, 2013 | 12:28 PM
Thanks.
Have a look at the cable to the starter, could be a bad cable or contacts at the ends, look at battery connections too. Bad connections do not like lots of power going through them and they just spark.
Old May 19, 2013 | 11:22 PM
I took the battery down to autozone and they said one of the cells was dead so they replaced it. Looks like my battery cables are good. I put it in the car and im still getting a one click sound everytime i turn the ignition.
Can I get a solenoid from autozone or do i need a bosch part?
Old May 20, 2013 | 11:15 AM
latemodel21's Avatar
Being one who looks for answers that don't include coincidence (ie your battery AND your solenoid failing at the same time), I would make sure that your new Autozone battery has a FULL charge before buying any other parts.
Chris
Old May 20, 2013 | 10:29 PM
U were right! The battery didnt have a full charge. She is up and running again.
Thanks for the help guys.
Chris
KDW4Him
18
Sep 1, 2021 05:47 PM
waldig
Jul 31, 2017 09:46 AM
jhansen
21
Feb 15, 2017 04:26 PM
Steven 4190
Aug 15, 2015 10:35 PM
waldig
Aug 5, 2015 02:29 PM
