Brake Pad recomendation please
Old Jun 3, 2013 | 06:54 PM
Buggin's Avatar
Default Brake Pad recomendation please
A few years ago, I "upgraded" to some Akebono pads. They stop great and have very little dust, however they squeal like a pig when stopping in reverse only. I've tried anti-squeal compond, swapping rotors, and even got a new set from Akebono and it's always the same. I'm really sick of sounding like I don't care for my car while backing, so I'm going to try a new brand of pads.
So, what do you recommend for a low dust, noise free, brake pad that is not absurdly priced?
Old Jun 3, 2013 | 07:12 PM
Default Re: Brake Pad recomendation please
My Akebono pads squealed when I got the car, I took them off, wire brushed the backs, cleaned off the rust on the supports, put brake anti squeal grease on the piston contact area, brake grease on the supports. Reinstalled there was no squeal, job done without the cost of new pads.
Squeal is vibration due to insufficient pad support generally.
Old Jun 3, 2013 | 07:22 PM
Buggin's Avatar
Default
I've done that before with no change, but I guess I'll try one more time... Thanks for the reply!
Old Jun 3, 2013 | 07:30 PM
I was all set to swap them out, but I had trouble getting the pads I wanted so I fixed them. I picked up the car in Florida and had 1,400 miles of squealing on the way home. They also appeared harsh, once fixed they were sweet and quiet, and stopped the car no trouble. Mine have no anti squeal gasket or whatever they call it, metal to metal.
Old Jun 3, 2013 | 07:35 PM
Buggin's Avatar
The weird part is that mine ONLY squeal in reverse. The OEM pads did not do this.
Old Jun 3, 2013 | 07:44 PM
Rotex Gold is the finest Kevlar metallic pad to date.
It offers excellent stopping power, combining top-rated performance with a long service life.
The friction material blends Kevlar with metallic soft steel wire and powdered sponge iron for maximum heat transfer, and silver virgin graphite for smooth quiet performance.
This 60% metallic blend reduces vibration which causes squeal, and runs virtually dust free eliminating the common problem of "black dust" on the wheels.
Perfect for drilled or slotted rotors.
Performance Brakes - Brake Pads, Brake Rotors and Brake Kits
Or order from our member here:
Ceramic brake pads by posi quiet
CENTRIC Power Alloy Brakes Cross drilled slotted/Ceramic brake pads for N/A and Srt6
Old Jun 6, 2013 | 07:11 PM
Buggin's Avatar
Thanks for the suggestion OneHundred. Although I've done the: remove, clean, lube and anti-squeal before without helping... this time it worked! I did also incorporate another suggestion I got: I filled the pistons with silicone before reinstalling the pads. I also put a small squirt on the back of the pads instead of anti-squeal. One note, I only had to do the rears as the front's were not making any noise. So far 3-days and not a peep! Let's hope it stays this way... and the whole job was free.
Old Jun 6, 2013 | 07:15 PM
ceramics for me.... any name brand...I have Hawks on the coupe...They still produce a little dust when used heavily....but pretty good other wise...
Old Jun 6, 2013 | 08:03 PM
It appears that Rotex Gold pads are made in Canada. See the thread attached and follow the link to the SRT forum.
chturner
19
Oct 14, 2019 04:42 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ritous1
Sep 26, 2015 01:27 PM
