A/C compressor voltage
I've been trying to run down a problem with my A/C. Fan works, all fuses good.
I've checked voltage at the compressor and it reads about 8 vdc. It does not change when the climate control is cycled on and off.
Does anyone know (or is in a position to check) the voltage that should be going to the compressor?
Thanks,
Robert
Thanks,
Robert
Manual says :
How could it be anything BUT the full 12 volts ?
Diagnostic Test
1. TEST THE A/C COMPRESSOR CLUTCH
Turn the ignition off.
Disconnect the inline connector C106 in the underhood relay control
module compartment.
Note: Check connector - Clean/repair as necessary.
Using a jumper wire to battery power, energize the A/C Compressor
clutch.
Does the A/C Compressor clutch energize?
Yes >> Go to 2
No >> Go to 3
module compartment.
clutch.
Yes >> Go to 2
No >> Go to 3
Well, this is german engineering at work
I know there are other devices that have a "trigger" voltage sent by a control module, etc.
I agree it should be 12 volts. I guess my concern was that it was 8-ish volts and constant with no change when cycled.
Per the manual, where is the C106 connector. I'm assuming it's not the one at the compressor as that one is pretty hard to get to...
Is that the K40?
THanks,
Robert
I know there are other devices that have a "trigger" voltage sent by a control module, etc.I agree it should be 12 volts. I guess my concern was that it was 8-ish volts and constant with no change when cycled.
Is that the K40?
THanks,
Robert
Here is an idea, it may not be low voltage:
Connect your meter's negative lead to the battery's negative post. Now, measure the voltage at the connector and THEN measure the frame/ground of the compressor - it should be near zero volts. If it is 4 volts or so, there is your missing voltage - fix your ground!
In any event, the voltage should change when you turn the A/C on and off.
Is that the K40?
THanks,
Robert
Is that the K40?
THanks,
Robert
Edit : SCRATCH THAT ! IT'S NOT ON THE K40, IT'S AT THE FRONT OF THE MODULE BOX.
You are a prince among men...
blackpepper
Oct 4, 2017 06:09 AM
atdavis2
Sep 21, 2015 01:25 PM
