Take the car to a garage or not?
Hi guys,
Just s quick question about my srt6,
I was driving to work yesterday and when I stoped at the lights the car lost all power all the lights where working and cd player was also working but the engine turned off, tryed to turn the key but nothing, but few min after I turned the key the car started up but the check engine light came on. So I parked the car and went to work, got back to the car started up as normal and no check engine light.
The car has been normal today.
What do you guys think happened, you think it's worth taking it to a garage? Or was it a just one off thing that I don't need to worry about every time I drive the car.
Thanks in advance guys.
Sounds like you lost power from the engine control relay on the Relay Control Board, this feeds power to the PTCM/ECM as well as other engine-related items - very, very common issue.
Remove the RCB and resolder every point on it.
Hi guys,
The last place you want to take your Crossfire is a garage.
Get an UltraGuage ( $69.95 before the $9 rebate ) - it will read and reset the codes.
( And as 180 pointed out, it will tell you when you are low on oil ...... NOT ! )
I have 2, one in the car, and a spare I picked up here on the forum for $35 )
Thanks for the replys guys, found out what the problem was.....the Crankshaft Sensor needs replacing.
The car stopped again so called green flag to recover it, the guy used his Diagnostic Tool.
What Crankshaft Sensor do I need to buy as in any brand I need to look out for or part number?
Thanks again guys.
Thanks again guys.
Thanks again guys.
Thanks again guys.
Our motto is "By Bosch or walk home".
Hi guys,
I got my Bosch CPS at German Auto Supply in North Carolina.
germanautosupply.com
I ordered their item 0 261 210 170 and got a Bosch MB# 003 153 27 28
Under $50 last year. Buy a Bosch or hate yourself for buying junk!
I still love myself and my Advanced Auto..
108 degrees.. ac blasting.. 80-85 mph.. didn't miss a stroke.. or the 100+mph sustained runs..
My Advanced Auto Borg Warner CPS was worse than my faulty OEM. Money down the drain POS. I'm not saying all Bosch is golden because it's not but it's the answer if your CPS is faulty.
Les
Les
Well when I got mine.. "Lifetime warranty".. so I won't be switching brands at this point. But the Bosch rides behind my seat and will only get used long enough to use that warranty.
i can't seem to find the Bosch Crank Position Sensor in the UK, but will ring Mercedes tomorrow and see what they have.
To the OP, if a Bosch is hard to find, pull yours off, clean it, reinstall with some dielectric grease and see if it resolves the issue.
I had bad luck with the Borg Warner but lots of cars are running them with good results. If you can do the work yourself use what you can find. The BW does indeed have a lifetime warranty and you may get a good one the first time out.
Now you know the rest of the story.
Les
Okay had to go get the box on my "new" one to see what brand they gave me.. is this the Borg Warner one that is giving most an issue with?
Standard Motor Products
We distribute parts under our own brand names, such as Standard, BWD, Hayden and Four Seasons, and through private labels. SMP products are distributed primarily to warehouse distributors, large retail chains, national program distribution groups, specialty market distributors, original equipment manufacturers and original equipment service part operations.
