datalogs LEAN AFR
Old Oct 28, 2013 | 08:13 PM
  #101 (permalink)
Default Re: datalogs LEAN AFR
You know as for me shooting just get to where everything is in harmony is what I like. And we are close.
Old Oct 28, 2013 | 08:26 PM
  #102 (permalink)
velociabstract's Avatar
I can't log the injector duty cycle. The dyno shop tried to tap into one of the injectors but didn't have success either. Therefore I don't know exactly where I'm at. Sigh ..... I don't wanna but if all youz guys say it's so, it must be so. I'll find a way to slip them on the Christmas list along with all the Ground Control goodies.
Les
Old Oct 28, 2013 | 08:36 PM
  #103 (permalink)
You know Les I thought I was done a long time ago. Rudy comes up with a 62mm pulley. It makes me do a fuel pump change. That means another tune. Then i find out the TCU can allow us to change rear end gear which I would have done at the Wavetrac mod. Now I have spare fuel rail to play with. I don't think it will end. The cars are my only hobby except for a firearm purchase now and then. But my part-time income is gone thanks to my recent injury. I guess I'm just venting but it is so much fun for this ole guy to keep making it a little faster. I could have had 1 hell of a Camaro built by now. But it would just be another Camaro lol.
Old Oct 29, 2013 | 10:32 AM
  #104 (permalink)
latemodel21's Avatar
Les
I can help you log your injector duty cycles. If you are interested, send me a PM
Chris
Old Oct 30, 2013 | 12:40 AM
  #105 (permalink)
JesseJamessrt6's Avatar
Chris
Another Latemodel21 goodie?
I am still running rich but can't decide if opening the exhaust to try and lean it out or just call Euro and get them to do a custom tune. There is a dyno up the road and I may get them to verify what my wideband is showing.
I think my goal would also be part of the FTS as the daily driver.
Old Oct 30, 2013 | 04:11 PM
  #106 (permalink)
[QUOTE=JesseJamessrt6;764921]Another Latemodel21 goodie?
necessity is the mother
Cheers,
Chris
Old Oct 30, 2013 | 05:31 PM
  #107 (permalink)
I have a new project for you. Find a way to log knock retard.
Les
Old Nov 16, 2013 | 02:05 PM
  #108 (permalink)
have some real logs from a couple 1/4 mile passes finally. Strange how the AFR starts rich and then by the end of the run leans out. I am also really surprised that with just a 62mm SC pulley I was showing up to 21 psi of boost. The last few logs the boost readings were really really low and not consistent so I am wondering if it failed. I also threw the P0108 over boost code on the last run.
Here is a log spinning most of the way down the track, I suck with street tires.
Here is the other log with more consistent TPS and RPM but the boost is readins are wrong
Old Nov 16, 2013 | 02:12 PM
  #109 (permalink)
grip grip's Avatar
You're running dangerously lean. I doubt you trapped faster than 112mph.
Old Nov 17, 2013 | 11:28 AM
  #110 (permalink)
Lenin's Avatar
Jesse, where do you have your Zeitronix boost sensor located?
Old Nov 17, 2013 | 11:37 AM
  #111 (permalink)
I ran some logs on Friday just normal driving and things are reading normal again. I have the sensor on the passenger upper intake manifold.
Old Nov 17, 2013 | 01:01 PM
  #112 (permalink)
hustler316's Avatar
What is everyone considering "normal" AFR? Forced induction should be around 10.8 - 11.2 at WOT. The extra fuel is needed for cooling, so if you are seeing 12.something you are still way lean.
Old Nov 17, 2013 | 02:00 PM
  #113 (permalink)
I have read here through past threads that 12 something would be as lean as we should be but 11 something would be ideal. I have really found out a lot in the past few months about the fuel system on our platform from this site and related links. I like that there is a science behind it and it changes from car to car.
Old Nov 17, 2013 | 03:53 PM
  #114 (permalink)
Buggin's Avatar
Hey Jesse, with the 62mm mine looks kinda like that. Not quite so lean, but the spike comes in around 5300 rpm / 19.1 psi boost. I also see boost upwards to 21psi at times. Been through a bunch of tunes and can't get it under control... so I've got my stock pulley pack on for now.
Old Nov 17, 2013 | 05:02 PM
  #115 (permalink)
hustler316's Avatar
Default
Without injectors and a better pump you will never be able to tune it.
Old Nov 17, 2013 | 08:47 PM
  #116 (permalink)
Lenin's Avatar
Between logging boost at the manifolds vs logging boost at the Y-pipe, which location produced higher boost reading and why?
Old Nov 17, 2013 | 09:17 PM
  #117 (permalink)
I never took it at the Y but I believe boost would read higher at the Y because the air hasn't expanded into the manifolds yet.
Old Nov 18, 2013 | 10:17 AM
  #118 (permalink)
Silverarrow's Avatar
Wow, that is high boost numbers you got there. How is that possible? I have the 61mm pulley mounted but never see higher boost then 19.6PSI.
Old Nov 18, 2013 | 10:39 AM
  #119 (permalink)
I have actually a secret for you. There is a MAP sensor looking exactly as the OEM one but are capable of 3.5Bar instead of the OEM that only can handle 3bar.
I have bought one for my self, don't have the part number but I can check it out for you by tomorrow. You would need a retune though
/Adam
Old Nov 18, 2013 | 12:38 PM
  #120 (permalink)
How do you get the boost signal? Through the OBDii from DashDaq or through the Zt-2 brain or is there a way to utilize two without confusing the system?
