Crank Pulley Fell Off
Old Nov 21, 2013 | 09:29 PM
lang's Avatar
Default Crank Pulley Fell Off
I have a 2005 srt6 and the crank pulley came off. I wanted to know how you put it back on, can you push it right back or have it pressed on? Can some one help me please. Thanks lang
Old Nov 21, 2013 | 09:38 PM
Default Re: Crank Pulley Fell Off
It is toast as I am sure the hub came away from the pulley. If It did not do much damage you are lucky. Buy another one and thank your lucky stars.
Old Nov 21, 2013 | 09:46 PM
lang's Avatar
Were could i get a new crank pulley from?
Old Nov 21, 2013 | 10:04 PM
I'd try MrMopar (click) at his shop first.
He may have one.
Good to deal with, but he may be a bit slow to answer a PM, so try email or phone.
Old Nov 21, 2013 | 10:16 PM
grip grip's Avatar
You'll need to confirm your keyway wasn't sheared off before you reinstall the pulley. It likely was, so you'll need to extract the remnants and install a new one and a new bolt with the pulley.
Old Nov 22, 2013 | 11:56 AM
32krazy!'s Avatar
did the outer ring come off or the entire pulley? did the elostomer between the hub and ring come out? slk32 crank pulley is about 250$ from oediscountparts.com . i have the crank pulley tool to hold it in place during torque sequence. torque is 147 ft/lbs PLUS 90* eat your wheaties
if the crank pulley hub came off the crank you most likely have a sheared keyway and possibly a damaged crank snout. pictures will tell us more
Old Nov 23, 2013 | 08:18 PM
waldig's Avatar
Talking Re: Crank Pulley Fell Off
I was one of the first to do this, boo. Bent the crank and killed the keyway, took some doing to cut a new slot wider for better key, not that 1/3 nickel sized one. Been ok, you had a loose bolt and deacceloration killed your pulley. Woody
Old Nov 23, 2013 | 08:29 PM
32krazy!'s Avatar
sorry woody but the elaostomer was coming out of the slk32 pullies 3 yrs before your car was built
Old Nov 23, 2013 | 08:39 PM
lang's Avatar
Got the car fixed, the guy that I bought the car from customized the car. He did not put locktite on the bolt, so the bolt came off. The person that helped fix it found the bolt stuck under the radiator and the frame, the car is running strong. Thanks for all of your guys help. lang
Old Nov 23, 2013 | 08:49 PM
32krazy!'s Avatar
the crank pulley bolt DOES NOT GET LOCKTITE. it is torqued to 147 ft/lbs then 90* more. its a one time use stretch to fit bolt and you have already used it past its purpose. there is a specific procedure for this bolt and following the locktite route will get you another failure.
Old Nov 24, 2013 | 11:35 AM
Billy22Bob's Avatar
Steve, do recall any photos of the elastomer issue?
Be good to stick a mirror/camera down there as a maintenance check, but it woud also be good to know what we're looking at.
Are Febi Crank Pullies okay? There's a couple out there in the mid $100's+freight.
I recall you ran the 178/65 stacked setup and have had lots to offer on these babies.
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 02:16 AM
