Changing ignition switch and lock cylinder
Old Dec 4, 2013 | 07:53 PM
PA/XFIRE's Avatar
Default Changing ignition switch and lock cylinder
Anybody out their have any knowledge or have done this ? If so chime in i'm about to attempt it as soon as I get the $350 dollar parts.THANKS LARRY
Old Dec 4, 2013 | 08:16 PM
Default Re: Changing ignition switch and lock cylinder
I have to ask.
Why is it being changed?
How to do it is in the "Sticky ignition fix".
Old Dec 4, 2013 | 10:56 PM
I have to ask.
With 418 Posts, I am curious myself...
Old Dec 5, 2013 | 10:36 AM
PA/XFIRE's Avatar
I have to ask.
Thanks 180. The lock cylinder problem, it locks when I get to the start position (can't turn starter on).Then their are times it does turn the starter on but stick in that position and the car will not start (possible safety to prevent starter damage ?), i manually have to turn the key to the left to stop the starter.At first I thought it was just a squirt of lock ease fix, but i'm way beyond that now.That "sticky ignition fix"article will be a lot of help. thanks again,LARRY
Old Dec 5, 2013 | 10:51 AM
My guess: the pulse module is bad. It is the pulse module that 'supervises" the starter's crank duration.
What do ya think, Dave? All automatic-transmission-equipped Crossfires crank automatically, right?
Old Dec 5, 2013 | 11:45 AM
Frankly I'm not sure it is an auto. I'd do the sticky key fix if it has not been done already and go from there before I spent $350.
Old Dec 5, 2013 | 12:41 PM
pjm30144's Avatar
I agree and would do the sticky Ignition fix. If the little block that rides in the grooves in the ignition housing is worn or has a bur or the spring is weak etc that could cause these symptoms. When I did mine I replaced the housing with a new one that I did the mod on. I took the old one apart to see all the parts. No wonder it starts to stick. Poor design.
Old Dec 5, 2013 | 01:14 PM
I went on the assumption that it was an SRT6 - given where the thread is.
Old Dec 5, 2013 | 01:17 PM
Slap me up the side of the head quick.
scheper
Aug 3, 2015 03:13 PM
gtjl
17
Jul 22, 2015 06:28 PM
Bayukbros
Jul 17, 2015 04:22 PM
66L72M21
Jul 15, 2015 04:23 PM
gtjl
Jul 8, 2015 07:42 AM
