reverse polarity
Old Dec 25, 2013 | 03:02 PM
blueeyes147's Avatar
Default reverse polarity
do you know if the srt 6 has reverse polarity on the battery?
Old Dec 25, 2013 | 04:35 PM
Default Re: reverse polarity
No reverse polarity, not sure what you mean but ....
The cars battery cables only fit one way, the correct way.
DO NOT TOUCH THEM THE OTHER WAY OR YOU WILL HAVE AN EXPLOSION AND RUINED ELECTRONICS.
Old Dec 25, 2013 | 04:49 PM
Charger brand ctek it says that if the battery is charging without disconnecting it from the car red clip is connected to the positive pole and the black one is not connected to the negative pole but on a metal part of the car, away from the battery or in the case of reverse polarity connected to the battery negative and the positive to the metal part of the case AUTOto our cars have reverse polarity?
Old Dec 25, 2013 | 04:54 PM
RED DOG's Avatar
The Crossfire does NOT have reverse polarity (and I've never heard of any car having reverse polarity)
Old Dec 25, 2013 | 06:11 PM
The reason all the charger vendors say to connect the negative lead away from the battery is to avoid a possible
'explosion' which the tiny spark could cause if the battery happened to be out-gassing combustible fumes at the time.
Really never heard of that ever happening, myself, but company lawyers have to put in that kind of legalese, they have families to feed too.
Old Dec 25, 2013 | 06:33 PM
dinasrt's Avatar
I think perhaps they are confusing the term "reverse polarity" for Positive Ground. The only car I've ever owned w/ positive ground was an old 48' DeSoto. Merry Christmas to all!
Old Dec 25, 2013 | 07:14 PM
I am thinking that blueeyes147 has a problem with the wording, he is interpreting the warning as a possible statement of fact.
The CTEK displays a warning if reverse connection to the battery occurs. Naturally the CTEK is connected to the battery BEFORE plugging the charger into the power outlet.
Old Dec 25, 2013 | 10:10 PM
dinasrt's Avatar
That sounds about right.
Old Dec 26, 2013 | 07:55 AM
you're right I think you understood what I meant
Old Dec 26, 2013 | 08:06 AM
TimTim's Avatar
FYI, I had a 1965 Triumph Spitfire with REVERSE Polarity. Positive Ground. It was a bear to work on.
Old Dec 26, 2013 | 09:47 AM
how will I ever know if my SRT6 has reverse polarity
Saluti
Old Dec 26, 2013 | 09:55 AM
Your SRT6 does NOT have reverse polarity.
It is a negative ground system, like all modern cars.
All you have to do is be careful when connecting any battery charger to first connect the positive ( red ) lead to the positive battery terminal, then connect the negative ( black ) lead to any convenient body ground point.
( or, if you are like me, connect the negative to the negative battery terminal, however I absolve myself of all blame should something bad happen )
Old Dec 26, 2013 | 10:02 AM
what brand and model of your battery has SRT6? I have problems with my remains stationary when (not used for a week) even with charger connected it is as if he lost power and the car starts, but incorrectly, as if he had problems with injection
Old Dec 26, 2013 | 10:26 AM
Padgett's Avatar
Correct, many English cars back in the day had positive earths. Lucas designed them that was so the components would protect the fuses but letting their smoke escape first. (and if you believe that one I have this prime Florida land with lotsa Cypress and Mangrove). Many also had two six volt batteries instead of one 12v and in inaccessible locations.
Americans hid fuel fillers, windshield wipers, and radio antennas. The Brits hid the batteries.
However the Crossfire is German so uses a proper 12v battery in a proper location. The Group Size is H6 and are available many places
Anymore I buy only AGM batteries. About a 50% cost premium for 3X the life.
ps anything that sits for more than a week (anything not in the front garage) has a $5 float charger on it. They always start right up, even the diesel.
Old Dec 26, 2013 | 10:37 AM
They are also known as series 48 batteries.
Old Dec 26, 2013 | 10:41 AM
you're telling me that it is normal to have problems with the SRT6 if the car is stopped in the garage for a week or more without a charger? the SRT6 is very sensitive to voltage drops?
Old Dec 26, 2013 | 10:48 AM
It is not normal with a GOOD battery, it would be normal with a WEAK battery.
Old Dec 26, 2013 | 10:57 AM
OPTIMA REDTOP : BATTERIA OPTIMA RT C 4.2 REDTOP ROSSA 50Ah SUV SIGILLATA FURGONI AUTO CHRYSLER DODGE JEEP 4X4 ALTA POTENZA RTC4.2
I have this battery, it is perhaps not suitable for my SRT6
Old Dec 26, 2013 | 11:00 AM
The Optima is a good BRAND battery, the condition however would depend upon it's age.
No, it should be OK with a good battery. As the battery ages and/or fails the uncharged time before it gets too weak will get less and less.
