mods
Old Dec 30, 2013 | 08:39 AM
austinbarrylee's Avatar
Default mods
Can someone please tell an estimate of hours to install NW Intake manifold, ECU, Pulley, PSK, Johnson IC Pump, Phenolic Spacers, SL55 fuel pump, AEM fuel regulator, Oversized Heat Exchanger
Separate,& Engine Coolant from Intercooler Coolant.
Thanks.
Old Dec 30, 2013 | 11:38 AM
meh03's Avatar
Default Re: mods
15-20 hours if you know how to install each.
Old Dec 30, 2013 | 11:39 AM
meh03's Avatar
Default Re: mods
Could take much longer. It took me about 6 hours to install the Johnson pump, but I'm very meticulous and take my time when working on the car.
Old Dec 30, 2013 | 11:57 PM
JEFASOLD's Avatar
Default Re: mods
Thanks.
Do you have all the tools? That is vital. One thing I have found very handy and almost never mentioned is a set of hose clamps, for DCAI and the SL55 pump and regulator. If you are doing all these mods you should think about a range colder on your plugs. Being careful and thorough, figure 3 eight hour days depending on your ECU tune.
Old Dec 31, 2013 | 12:00 AM
Default
He has all the tools. Range colder for the plugs??
Old Dec 31, 2013 | 12:15 AM
JEFASOLD's Avatar
Default Re: mods
You need the plug tip warm enough for self cleaning but it needs to be cool enough to prevent pre-ignition. The increased air, fuel from your mods will produce a hotter chamber, hence the need for a plug that will conduct heat away better, a colder range plug conducts the heat away faster than the stock plug.
Old Dec 31, 2013 | 12:19 AM
Default
So basically your saying I need a tune up too. New spark plugs. Wires too? What kind of spark plugs & can i get them from auto zone so I don't have to wait on shipping.
Old Dec 31, 2013 | 12:28 AM
JEFASOLD's Avatar
Default Re: mods
I don't have access to the numbers without a search but NW sells them, NGK iridium tips, you can probably get the # from Robs site. I don't know if your local auto parts would have them or not but anyone who carries NGK should. Many have gone to aftermarket wires but I think stock is fine, they are a good quality wire. Where are you getting your ECU tune from?
Old Dec 31, 2013 | 12:32 AM
Default
I will contact Rob tomorrow. I ordered parts from him today. He said my order is going to shipped tomorrow. Maybe I can catch the order before it goes out. ECU is getting done by Eurocharge. I am going to mail them my ECU and they are going to mail it back.
Old Dec 31, 2013 | 12:35 AM
Default
NGK Laser Iridium Spark or NGK Iridium IX Spark
Old Dec 31, 2013 | 12:40 AM
JEFASOLD's Avatar
Default Re: mods
You will love how the car feels with all the goodies on, it will be transformed from a very quick car to a real beast. Are you considering or have you done anything to increase the handling prowess of the car, wider wheels and tires, spacers, camber kits, lowering? Good luck with everything.
Old Dec 31, 2013 | 12:46 AM
Default
Thanks for the help. The car is lowered with eibach spring. Purchasing Mandrus Millenniums rear will be 19x9.5 with 275/30 ZR19 et 35 . When purchasing wheels I am going to be camber kit bolt from NW and KYB shocks.
Old Dec 31, 2013 | 12:50 AM
Default
Which plugs do you recommend NGK Laser Iridium Spark or NGK Iridium IX Spark Plug
Old Jan 1, 2014 | 12:01 AM
JEFASOLD's Avatar
Default Re: mods
Sorry I didn't get back last night, went to bed. I have the NGK Iridium IX that Rob lists as 1 range colder.
Old Jan 1, 2014 | 12:29 AM
Default
Thanks. New Year. Other forum members helped me out.
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
