misfire not detected appliance bosch for the diagnosis
Old Jan 24, 2014 | 10:28 AM
blueeyes147's Avatar
Default misfire not detected appliance bosch for the diagnosis
any of you have had problems with misfire detection and diagnosis did not detect the error?
Old Jan 24, 2014 | 01:10 PM
sk8erjosh09's Avatar
Default Re: misfire not detected appliance bosch for the diagnosis
Nope, but I use Mercedes' diagnostic's system. I have however had a "cheap" (relative in respects to DAS) $100 walmart scanner not detect quite a few codes before.
Old Jan 24, 2014 | 01:26 PM
so you're telling me that it is possible there is a misfire and that this is not detected by the OBD? do you know if the SRT6 is a problem that often misfire?
Old Jan 24, 2014 | 01:55 PM
It has to be consistent to throw a light, and there has to be a light for your dime-a-dozen scanners to pick something up. If you're misfiring and you are sure about it I would check the MAF, Crank angle sensor, cam position sensor, and vacuum lines, in that order.
Old Jan 24, 2014 | 02:06 PM
is a bosch obd, the carryover to tomorrow bosch car service them fail to see the error, tell me what I should do in order to control? seeks to specify well because they are Italian and it might be difficult to translate
Old Jan 24, 2014 | 02:30 PM
Josh is saying :
1. Replace the MAF sensor. ( Mass Air Flow sensor )
If that does not resolve the issue, then
2. replace the CPS ( Crankshaft Position Sensor )
3. replace the Camshaft Position Sensor.
4. Use some method that detects vacuum leaks to ensure none exists.
One method is to use an UNLIT propane torch and pass it close to any suspected source of leak, if the engine smooths out, you found the leak.
BE VERY CAREFUL WITH THIS, AS YOU ARE INTRODUCING AN EXPLOSIVE ELEMENT INTO AN AREA WHERE SPARKS MIGHT EXIST !!!!!!!!
I disclaim any responsibility if you or the mechanic chooses to use this method.
Old Jan 24, 2014 | 02:39 PM
Josh is saying :
Thanks George. ^^^^^^^^ There's the answer
Old Jan 24, 2014 | 02:44 PM
Josh is saying :
so most of the parts to be inspected and possibly replaced all sensors are not mechanical parts?
Old Jan 24, 2014 | 04:35 PM
The MAF is a plastic thing attached with 2 screws.
The CPS is also a plastic part attached with one screw.
The Camshaft Position Sensor also is plastic, attached with one screw.
All 3 have an electrical connector.
Old Jan 24, 2014 | 05:21 PM
[QUOTE=ala_xfire;778138]The MAF is a plastic thing attached with 2 screws.
All 3 have an electrical connector.[/QUOTE
Thank you very much tomorrow I will give this information to the bosch car service, if you have any other tips let me know thanks
Old Jan 24, 2014 | 05:27 PM
this is the problem, it seems only a misfire that almost always happens when the car is stopped one or two days sometimes happened after a week of detention and almost never with car in motion a couple of times, this problem does not appear to diagnosis bosch
Old Jan 24, 2014 | 08:23 PM
Holy ****! That is something serious. I'm sorry but I have no experience with something like that. That is NOT a misfire.
Old Jan 24, 2014 | 08:53 PM
philosophico's Avatar
Just a correction. A srt-6 does not have a MAF, only the regular crossfires have one.
Old Jan 24, 2014 | 09:03 PM
N/A's? True. He never specified model so I assumed.
RED DOG
Oct 5, 2015 07:59 PM
Sep 25, 2015 02:16 AM
getshawty
Aug 24, 2015 10:30 AM
Romio
Jul 24, 2015 07:03 AM
xfireon20z
Jul 20, 2015 04:35 PM
