Intercooler tank
Old Feb 17, 2014 | 01:21 AM
dinasrt's Avatar
Default Re: Intercooler tank
Originally Posted by ckovach
I used a Meziere 28-oz tank.
Meziere Enterprises
Very nice. I like that better than the plastic BMW PS tank.
Old Feb 17, 2014 | 09:03 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
oh yah....I gotta get me one of those!!!
Old Feb 17, 2014 | 10:40 AM
JesseJamessrt6's Avatar
Originally Posted by amx1397
I know it looks dirty but the paint peels off because it gets so cold,this is a 3 1/2 gal. tank.jim
Nice tank, that is a lot of volume, custom right?
Old Feb 17, 2014 | 12:05 PM
dinasrt's Avatar
IIRC, Jim posted a video of that tank flowing with his killer chiller hooked up. I couldn't believe the flow; it was like a swift babbling alpine stream.
Old Feb 17, 2014 | 04:52 PM
amgstyle's Avatar
Meziere Enterprises
did you buy the coolant expansion tank or the coolant recovery tank ???
Old Feb 17, 2014 | 08:02 PM
Temp Of Water In Tank After The Intercooler Video by amx1397 | Photobucket
here is a video of my tank and the temp low temp from the killer
the cab has the OEM ac unit . and it gets cold in the car. then i tied into the high and low AC lines ,set the killer up below the front bumper brace, added the water tank, and added 1/2 lb of freon jim
there are more videos just go to the next one
Old Feb 17, 2014 | 10:47 PM
ckovach's Avatar
Coolant expansion tank.
Old Feb 18, 2014 | 02:01 PM
Billy22Bob's Avatar
Originally Posted by velociabstract
With the separated circuits and connected circuits the maximum IAT temperatures on the road course are the same as far as I can tell.
Les
Interesting. I've never been a fan of the principal of separated circuits unless your wanting to run different coolant/wetter etc. The leaking intercooler issue you mention adds another dimension to the design as well.
...........So when your WOT and your cooler is leaking- say MAP=>16psi - it pumps up your coolant tank/system and then I guess the cap releases at something less than this (even though it's not effectively boiling) - so you get residue/spray coming out everywhere. Wow!
I guess that's one way of confirming you have a badly leaking IC then.
I did have a link to the Beamer PS tank on ebay ~$20 but it's just dropped off my watch list.
Old Feb 18, 2014 | 03:28 PM
dinasrt's Avatar
What happened to Les was because he was running a BMW PS reservoir tank like myself. They have an 1/8" breather hole in the cap(vented/no pressure). Obviously it would never have spit unless his CAC was ruptured/cracked. That doesn't make the tank a BAD thing. I like being able to open the cap after a hard run at the track and sticking my little finger in to see how warm it is. You wouldn't do that with the engine coolant system. The only negative that I could imagine is the two separate temperatures and pressure differential on the opposing walls of the CAC exchanger. I think Woody may have talked about this a long while back, and is probably where I read about it. IIRC he talked about an accordian like dynamic that could (MAYBE) be working the already thin/weak metal walls of the CAC exchanger. Is this what is causing the failures, or just speeding up the inevitable? Either way, I really would like to get one of Rudy's CAC upgrades, sooner, rather than later. I believe with his, we wouldn't have to be concerned one way or the other about this occurence.
Old Mar 1, 2014 | 05:33 PM
BrianBrave's Avatar
<--- Huge Horsepower
Meziere Enterprises
Me Too! (was it really 5 1/2 years ago?)
Old Mar 1, 2014 | 05:49 PM
dinasrt's Avatar
You sir, have inspired many of us here on the forum. Thank you.
paine2907
Oct 2, 2015 10:01 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
Ralph289
Jul 26, 2015 12:52 PM
Romio
Jul 24, 2015 07:03 AM
RED DOG
Jul 21, 2015 07:58 AM
