AVT Bosch Intercooler Pump
Old Feb 16, 2014 | 12:13 AM
Billy22Bob's Avatar
Default AVT Bosch Intercooler Pump
I may be up for a IC pump
Found these over on Ebay.
Seem to pack a bit more punch than the Johnson30 and look a lot more like the original.
I also like the look of them since their larger diameter means they wouldn't have to work/rev as high as the Johnson to achieve the end game (flow and pressure). Last longer????...maybe
But the only specs listed are - 1,200-1,700lph up to 5psi. So I'd figure the 5psi would be for the 1,200lph (5 USGpm) figure...?
.....but capable of 8psi - I'd think this means dead head....?
More specs would be good if anyone has them..
It's not as long in the legs as the Johnson CM90's, but with the restrictive IC and stock HX, long legs aren't what's needed here, psi head is. Because of this I'm guestimating it might even pull more water than the 20mm CM90 in a stock application.
Need to check the AWG's for the Amps and see how the 5A fuse handles it - just to keep it safe.
Anyone tried - thoughts?
I don't need to be convinced of the popularity of the Johnson CM30 (or CM90) - Just looking for people who have looked at (and maybe even discounted), but might have dug up some detail on these AVT pumps.
Yes - they are a little more expensive
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270965688820
Old Feb 16, 2014 | 01:21 AM
dinasrt's Avatar
Default Re: AVT Bosch Intercooler Pump
You are the smart one with all your figures and calculations; you should perhaps just go buy the thing. Hook it up and give us your analysis. What could go wrong?
Old Feb 16, 2014 | 01:50 AM
latemodel21's Avatar
that appears to be the ford F-150 version of the bosch pump .... it works fine (I have it in all 3 of my supercharged daily drivers)
if you want to pay less
Bosch Intercooler Pump Lightning Cobalt 392022002 Cobra | eBay
or if you feel that there is direct relationship between cost and benefit, you can get this one Bosch Intercooler Pump Lightning Cobalt 392022002 Cobra | eBay
both are the same (of course) and require that you use the old pump housing from your stock unit (6 screws) AND you will need to change your connector to that of a bosch EV1 style connector
Cheers,
Chris
Old Feb 16, 2014 | 03:15 AM
Billy22Bob's Avatar
Cool Chris - owe you a beer.
Deed's done
this one includes pigtail.....here
I wonder how many of those $999 ones they actually sell.
Old Feb 16, 2014 | 03:40 AM
Deed's done
that's the shocking part .... it says 38 SOLD !
I kept searching the auction for "price is for box of 10 pumps" but found it nowhere
caveat emptor ...
Old Feb 16, 2014 | 05:27 AM
syfi's Avatar
I would simply stick with the proven #10 Bosch for around $100. No worries about over pressure/flow rates and are well tested. And no modding of the plug and housing; P&P.
Thought I read where the higher pressure from the Johnsons were causing some leakage on some OEM coolers. But if you have Rudy's modded one then I say go ahead and push it.
Guaranteed to Fit, Guaranteed for Life and free shipping! (well at least for US orders)
Mercedes Auxiliary Water Pump - Bosch (OEM) 0392022010 | FCP Euro
Old Feb 16, 2014 | 01:30 PM
Billy22Bob's Avatar
Yeh - I read this too, but cant see how an extra couple of psi of constant pressure across the walls of these things would be that significant when it's seeing significantly minus (-9?) psig up to >+14psig cycles all day long from the throttle.
Old Feb 16, 2014 | 01:39 PM
I agree this is a better way to go than the F-150 version of the bosch (that I used on 3 of my cars). direct plug in and a great price. Had this deal been available when I replaced mine, I would not have thought twice about buying this unit.
Cheers,
Chris
Old Feb 16, 2014 | 02:26 PM
$106 is a REAL bargain, IF they really honor that "Guaranteed for Life" promise.
Old Feb 25, 2014 | 02:03 PM
Billy22Bob's Avatar
Deed's done
392022002 Bosch Pump arrived today with pigtails (+$6US) (which is cheaper than the link I posted - mates rates I guess).
Will hopefully be able to try it out on the weekend.
Old Apr 10, 2014 | 11:23 PM
Why did you buy the pump that fails all the time? That pump is in your car from the factory. You should have gone with the newer version #392022010.
You could have had my old 02 pump which I have just replaced before it broke on me for a song.
Old Apr 10, 2014 | 11:46 PM
Billy22Bob's Avatar
old news - but thanks anyways.
"That pump" turned out to be a total piece of crap.
I got sold a lemon - it didn't even perform to the 392022002 specs. All I could get was 8lpm (2.1GPM) at 1.2psi with 3Amps at 13V
New News -
I fired up a new Pierburg CWA50 last night and it looks the goods - 16lpm (4.2GPM) at >7psi and only 4.2Amps at 11.3V. Soft start and virtually self priming.
So it may even be good for ~6-8GPM within my circuit - will see.
But....they can be a little pricey unless you keep your eye out for a bargain.
Old Apr 11, 2014 | 01:59 AM
UK-John-SRT-6's Avatar
Listen to these guys ( including 180 )
they pointed me in the right direction. I have just replaced the pump with the Bosch 10 model and also the crank case sensor
car goes like stink
Old Apr 11, 2014 | 08:06 AM
New News -
I feel for you down there, we think we get ripped off up here in Canada, but looking at your prices, shipping etc we get off lightly.
I too have used US members, most notably one who I do not want to get swamped with requests for help, to help me get things from suppliers who will not ship out of the US. These suppliers must be doing real good to turn down business, lazy more like it. They do not want to go one extra step, filling out a form - big deal. Same packaging no real problem, maybe in some cases their boss does not know.
RED DOG
Oct 5, 2015 07:59 PM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
Sep 25, 2015 02:16 AM
