Intercooler Isolation Kit/Needswings
Old Apr 25, 2014 | 10:58 AM
Da55id's Avatar
Default Intercooler Isolation Kit/Needswings
My son bought me the IC isolation kit (what a fine lad!). Is there an installation thread for the IC coolant separator kit? The images/instruction seem pretty sparse on the Needswings site (no offense Rob) and there were no instructions at all in the box.
Also, I have not seen anyone comment on before/after performance changes. I'd love to hear opinions/experiences.
Old Apr 26, 2014 | 12:05 PM
Leptronjohn's Avatar
Default Re: Intercooler Isolation Kit/Needswings
I received my kit yesterday, Rob emailed me the instructions before i got the box,
give him a call or I can forward a set to you,
it saves the intercooler as in the past under higher water pressures the cooler will start leaking. Also it helps keep the intake air cooler.
I have many of Rob's parts, they are the best. service is the best.
john
Old Apr 26, 2014 | 12:18 PM
Da55id's Avatar
Thanks! Rob contacted me and said he was updating the instructions.
Old May 5, 2014 | 07:10 PM
podea's Avatar
I just did it.
Radiator return temp at shut-down is still 150 degrees but the S/C return line now runs 110 degrees at shut-down.
That's 27% cooler than before. Seems to accelerate faster too.
PFO
Old May 29, 2014 | 02:06 PM
JimmieC's Avatar
What is the purpose of the 1/4 inch discharge hose that goes on an angle from the intercooler return aluminum tube to the tank? I do not understand why Mercedes ever designed it that way. Saltbranch, are you having a problem?
Old May 29, 2014 | 02:40 PM
NeedsWings's Avatar
to purge out the air bubbles in the system.
Da55id, you got the instructions and are all set correct?
Old May 29, 2014 | 03:09 PM
Da55id's Avatar
Hi Rob, As far as I know it's all installed and operating as intended. No leaks, no runs, no puns.
Old May 29, 2014 | 03:40 PM
Let me be the first to congratulate you on being the Car Of the Month for June on Drag Times.
Please can you tell us where does the little hose from the IC pump go. The nipple is plugged on the new pumps. It appeared to be dry when I took it off the old pump so I assumed it was drain, but the hose just disappeared upward.
Old May 29, 2014 | 04:42 PM
NeedsWings's Avatar
the other end of that hose is open to atmosphere in the engine bay. it is not needed on the new pumps, bosch stuck the dead "nipple" there so you would have a place to attach the dead hose, which can still make it equally confusing, lol.
so the hose is not needed, either remove it from the car or leave it hanging there doing nothing. it is intertwined into the IC fluid hose assembly so I just left mine there
xfireohio
Jul 20, 2020 12:03 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
Ralph289
Jul 26, 2015 12:52 PM
Romio
Jul 24, 2015 07:03 AM
RED DOG
Jul 21, 2015 07:58 AM
