help installing karman pulley
Old May 12, 2014 | 06:15 PM
austinbarrylee's Avatar
Default help installing karman pulley
with the bolt tight the pulley can move in and out about 3/16 of an inch. it appears to need a spacer between the washer and the pulley bearing to hold it back
Old May 12, 2014 | 06:59 PM
Default Re: help installing karman pulley
The Karmann pulley should come with a 5mm (.197") spacer as the bearing is 5mm shorter.
Old May 12, 2014 | 07:03 PM
one hundred 80 pm
Old May 12, 2014 | 10:17 PM
The problem is i dont the small ring. My pulley didnt come with it. Can I use a stock one.
Old May 12, 2014 | 10:57 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
You need both the ring shown in the picture above and the stock bolt flange washer. Where did you buy the pulley?
Old May 12, 2014 | 10:58 PM
No, the OEM washer fits in the recess cut into the spacer you should have got with the pulley. You need the spacer to make up the difference in length of the two different bearings. Without the spacer you will not be able to clamp the pulley in place.
Old May 12, 2014 | 11:28 PM
I got it from RedDog's friend who manufactured the product.
Old May 12, 2014 | 11:30 PM
Go look through your original shipping box and packaging too make sure the washer is not hiding on you.
Old May 12, 2014 | 11:31 PM
Clamp on to place. Right that's why it moves. I don't know what to do.
Look it's not.
Old May 12, 2014 | 11:34 PM
Put the stock pulley back on and call the seller for the missing part. Cant use the pulley without it. No biggie. Just have to wait a couple more days. Did it get shipped directly to you or from Red Dog Bob?
Old May 12, 2014 | 11:36 PM
Directly to me. Is there a way I can buy the ring or get one made. Looks like another delay.
Old May 12, 2014 | 11:39 PM
I don't have stock pulley sold my pulley to Red Dog.
Old May 13, 2014 | 12:49 AM
I bought from Khang Vo.
Old May 13, 2014 | 12:58 AM
RED DOG's Avatar
It came with that washer that you need. He wouldn't have sent you the pulley without that washer part. Let me know if you need Khang Vo's contact information again.
Old May 13, 2014 | 01:01 AM
No washer. The mechanic just tried to install it and asked me. Please send me contact. Thank you
Old May 13, 2014 | 01:08 AM
RED DOG's Avatar
PM sent with Khang Vo's contact information . . .
Old May 13, 2014 | 01:11 AM
Old May 13, 2014 | 01:13 AM
RED DOG's Avatar
There seems to be an annoying echo in here . . .
Old May 13, 2014 | 01:16 AM
We are in a cave.
tom2112
Oct 26, 2015 08:18 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
Tp'sfury
Aug 13, 2015 08:20 PM
Jul 29, 2015 06:13 PM
