Help needed badly, ASAP
Old May 31, 2014 | 06:20 PM
Silverarrow's Avatar
Default Help needed badly, ASAP
Hi everyone,
As you know I have been struggling with the engine code P1107 which says that the map sensor circuit is low voltage.
I have tried everything and done all kind av tests according to the manual. I have recognized one thing though. According to one diagnostic test it says that if the voltage is between 4.7 - 5.2 volt when measuring the voltage on the map connector when the ignition is on then I have to change the power control module.
I was wondering if anybody here on the forum can measure the circuit voltage on the map sensor connector when the ignition is on. Just disconnect the map sensor and measure the voltage over pin 1 and pint 3.
If someone here has the custom manifold from needswings it would be a lot easier because the stock one is sitting on the intercooler which is hard to get hold on.
I will go to the garage within 8 hours and would appreciate if somebody could help me.
Thanks in advance
Old Jun 1, 2014 | 05:56 PM
Default Re: Help needed badly, ASAP
Hehe, no one here to help
Old Jun 1, 2014 | 07:07 PM
I thought you needed it right away... I will see if the battery is up on my circuit tester.... knowing me, it isn't...I have a tendency to leave it on...
Old Jun 2, 2014 | 01:20 AM
That Would be great, thanks
Old Jul 3, 2014 | 02:27 PM
Hi everyone,
I just wan't everybody to know that Jerry at eurocharged is the king of all kings regarding finding and fixing problems. As all of you know I haven't been able to use my car the last 8-10 month because we have been struggling with a map sensor issue which generated the P1107 CIL error saying "The supply voltage to the map sensor is to low". After many many hours in the garage I have almost gave up on this project and was honestly thinking of selling my car even if I couldn't get a cent because of the error. But with the help of my fiancee, my brother, Rob at Needswings and of course Philip(FUBU) I kept the fire going until we narrowed down the problem to the newly installed throttle body. I have read on the MBworld forum that other people had similar issues even if the code was different and a couple of days ago I read that mr Jerry found the issue. I mailed him my tune and a couple of hours later I got it back. Today my mechanic put the tune on a chip and after installing it we where crossing our fingers and YES the CIL didn't show up.
I'm the happiest guy in Sweden right know and for the first time I could put the pedal down without feeling that the car is not working as it should. The car is so strong, it pulls like never before. I didn't have my SD card in the DashDaq so I can't put up a log but will do it within a couple of days.
So everyone, if you have a problem in the future with your car Jerry is the one to call.
There are only one mod left to do and that is the installation of the Killer Chiller. Hopefully it will arrive within a couple of days and will install it right away. I think that the killer chiller and the meth installation will be the answer to our heating issues we are seeing on our cars.
If somebody is interested in a killer chiller please call Joe at 505-275-2665 and say that I sent you to him.
Have a nice one everyone
/Adam
amx1397
Jan 24, 2016 02:12 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
Trenzman
Jul 24, 2015 10:12 PM
xzmilan
Jul 22, 2015 10:40 AM
Mark McKay
Jul 17, 2015 01:18 PM
