blew the engine!!
Old Jun 9, 2014 | 10:38 AM
sk8erjosh09's Avatar
Default Re: blew the engine!!
Based on some of his previous posts it's supercharged. I wonder if the crank pulley is loose. He would have spotted that though.
Oh, ok. Yeah, I thought of that too, but it probably would've been spotted. It still doesn't explain how it seized though. That's crazy.
Maybe a bad tune? Driving like a hooligan like me?
Old Jun 9, 2014 | 10:41 AM
For the record, the 32 block I have seized on the guy that had it. There's starting to be more and more 55K guys seizing too.
Old Jun 9, 2014 | 11:08 AM
grip grip's Avatar
He said later on in post #17 that it isn't seized.
Old Jun 9, 2014 | 11:21 AM
Skipped right over that. I blame lack of coffee lol.
It could be the oil pump. A video of the squealing would help, it could be a ton of different things.
Old Jun 9, 2014 | 06:46 PM
sailorsam's Avatar
I would post a vid but, i don't want to run the engine for fear of further damage. I turned the crank with a socket and it turned ok, the pulley did not appear to loose. I'll be pulling it out this week so hopefully i'll be able to find the root cause of the failure.
Old Jun 9, 2014 | 10:04 PM
vinnys's Avatar
Save the time and drop the pan and check the main and rod bearings. Pull the supercharger and check the gears and bearings in there. Why pull the motor when you have no clue as to whats wrong with it???? Check the alternator, that will squeel if its bad. If the alternator is not putting out, the car will run for a short time untill the battery goes down and the car will quit. I have never been deep into one of these motors, but I need to know whats wrong before I pull a motor. But thats just me. Good luck!!
Old Jun 25, 2014 | 12:34 AM
sailorsam's Avatar
Well the engines out and i now know what happened. When the belt broke apparently some piece or pieces got lodged behind the harmonic balance and through the front main seal.The metal part of the seal got pushed back into the oil pump chain. The chain apparently jammed causing the timing chain to jump. I've verified the timing chain jump by trying to align the cam locking grooves(they wont line up). I can't seem to find a timing mark on the harmonic or any where else for that matter. The service manual says " Rotate the crankshaft to 40° ATDC" I can't figure out how to find 40 degrees exactly with no indicator. I will be posting some pics tomorrow if i get a chance.
Old Jun 25, 2014 | 09:18 AM
Speedy4x4's Avatar
Glad to hear it is not internal. You have any good pics of what happened?
Old Jun 25, 2014 | 09:50 AM
ImportLabSRT's Avatar
The timing marks are on the harmonic damper (crank pulley). You will need to line up the balance shaft as well.
Old Jun 25, 2014 | 11:14 AM
sailorsam's Avatar
ok, so here's what's left of the front main seal. As you can see it got chewed pretty good by the oil pump chain.
Old Jul 2, 2014 | 12:44 PM
sailorsam's Avatar
Well,
The damage was Extensive!! piston's, valves, Heads, oil pump.
See the attached pics. So i've swapped the heads, swapped my cams to the donor
heads, Cleaned up the piston faces with my dremel, ordered a new oil pump, ordered
new head bolts, gaskets etc. Now the rebuild begins. Amazingly there's no damage to
the cam chain, oil pump chain, crank gear, cam gears.
Old Jul 2, 2014 | 01:19 PM
Make sure you get all the debris out of the oil and coolant passages. Are you cylinder walls scored at all? If so, you are better off swapping another engine in than trying to fix it.
Old Jul 2, 2014 | 02:23 PM
sailorsam's Avatar
Cylinder walls look good. everything has been flushed.
Old Jul 17, 2014 | 10:59 AM
sailorsam's Avatar
The Rebuild is complete and the engine is in. It's running better than ever!!! This has been quite A "Learning experience" I've built or rebuilt several engines in my day, bu i've never seen anything like the design and engineering of this thing! I hope I never have to do it again.
Old Jul 17, 2014 | 11:16 AM
Congratulations !!!!
You're a better man than I am, Charlie Brown.
Old Jul 17, 2014 | 11:52 AM
tighed1's Avatar
DUDE!
You coulda had a V8!
https://www.crossfireforum.org/forum...p-special.html
MiamiTVR
Jan 30, 2016 02:15 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
